Fabricating new headrests
  • Fabricating new headrests
    As the monitors are too big for the headrests, I decided to fabricate othere headrests that would fit the monitors I got from Armen (Thanks again!).
    As I couldn't find any Ford headrests, I got some random ones wich I stripped leaving me with only the metal bar.
    This is how they turned out:
    Renault Megane...the OEM look
    As the distance between the bars was too small, I gave them to a friend of mine and he welded a pice of metal between.
      This is the original headrest:
        Here you can see that the headrest was too small for the monitor to fit. I've read Altimat's tutorial for small headrests, but these were too small for that.
          I then cut other 2 pieces of MDF for the front of the headrest, and attached it to the frame. I don't really trust glue, so I used screws.
            I used two pieces of thin wood to attach the monitor shroud to the frame.
              Time for the foam to be applied. So I made an MDF box for the foam to expand in.
                Foam applied:
                  interesting..
                  that expanda foam won't be too soft of ur head?
                  View My Blog
                  Click for 2GB FREE on-line storage!
                    Damn, nice work so far!! Those monitors kick *** too!!
                    I can't wait to get mine back from Altimat.
                    Spent so far: $1,755
                    Check Out My Work Log for Specs/Pics
                    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
                    Don't mess with Texas.
                    It's not nice to pick on retards!
                      Originally posted by djmickyg
                      interesting..
                      No, actually it's quite perfect. A bit hard, but that's how I'd like a headrest to be. The original ones are a little bit softer though.
                      Thanks Edrex!
                        I don't like this foam. Almost 30 hours and it still isn't dry in the inside.
                        Edit: should've applied it in layers.
                        This is what it looked like when it was dry.
                          You gotta run that foam in layers if you want it to dry, even if you apply it in layers and give it half an hour or so between shots it'll get enough air to expand and breathe. It'll dry eventually, unless you got a bad can of foam. Try putting it in the oven on LOW for an hour or so.
                            Thanks Dave, thought of putting it in layers, but then again I'll be busy for a couple of days, so maybe it will dry by it self. From time to time I make a hole in the foam for it to breath inside.
                            Nice suggestion, but the oven is the last place I'll put something like that!
                            I then cut it to shape. Everything will be covered in soft foam, but right where the head will be, I've put in a bit more.
                              This is not done yet. The monitor isn't fitten properly, as well as the screen. This is not the actual cover, but a rough one I made so I'd get an ideea. It will be covered in fabric.
