Screen Mounting (Flip up or Dual View)
  • Screen Mounting (Flip up or Dual View)
    So heres my Dilemma I'm debating permanantly mounting two screens side by side (one for driver and one for passenger)
    OR having one (actuator/motor?) driven screen that would vertically go into place on drawer hinges or something similar and then go back down when the van was off so that it looked stock.
    ADVANTAGES TO TWO SCREENS
    driver and passenger can control individually
    will look cockpit like after completion
    DISDVANTAGES TO TWO SCREENS
    More Bondo work
    if dash is stolen they got 2 screens now and all the custom work
    ADVANTAGES TO ONE SCREEN
    Cheaper
    Antitheft
    DISDVANTAGES ONE SCREEN
    Dont know where to find hardware motors etc
    More electrical stuff to do. (relays stepper motor?)
    Screen in center may lead to spilling beverages versus not having cup holders in the 2 screen setup
    I did some searches but didnt get much back are far as steppers etc
    i was hoping someone might have a suggestion for an eisier way to do the actuator if i go that route
    I need some options from you guys what do you think would be the best way and what whould i use to accomplish the actuator hardware if i went one screen
    Here it is now
    What it is like taken apart
    I want to make it slide up from this spot LOWER
    To this spot UPPER
    Here is the shroud which will make a good base to hook onto just not sure what type of actuator i could use
    OR have 2 screens at passenger and drivers access bondo'ed into the center console
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    One way to do this is use a linear actuator. I looked into this when building my screen but they were a little pricey ($120 or so). I took a different route. If you want details, check my sig for the install.
    Want to:
      if you need a 12v linear actuator let me know. I've got one sitting around that I never used for another mod. PM me if your interested
