8" lcd for 98-02 accord?
  • 8" lcd for 98-02 accord?
    Hi, anyone here who has used an 8" monitor on their 98-02 accord dash? Because I'm contemplating between 7" or 8" for my project..
    Thanks!
    anyone?
      the LCD inside lilliput 8" is 7-3/8" x 5-5/8" with thickness 7/8". you could use a piece of foam or something to mock it and try how to mount it. I guess you probably need to fabricate a piece as its frame and cover the trash space below.
        you've got to cut and trim for a 7" to fit in the double din opening. an 8" is going to require some major work
        AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
        MediaEngine front end, map monkey, netstumbler.
        gps mouse is on the fritz.....stupid technology
          Indeed. My 8" is mounted outside the double din, in front. It works, but the 7" wouldve worked better. If you want to flush mount in the dash, go with the 7". If other options are acceptable, the 8" is a little easier on the eyes IMO. Good Luck!
          Carputer status: [-*---------]
          Im thinking laptop...
