Indash Retractable Keyboard - in progress
  • Indash Retractable Keyboard - in progress
    Some of you might know that I've been working on putting a pc in my car with a digital dash. Being short on excess cash (and time), I've had to put the LCD project on hold for a week or two. But I've got so many things half done, I need to get something solid to satisfy my car modding cravings.
    Some I start thinking about getting around to the keyboard. This is what I want.
    There's so little room there, so I'm thinking about what I can use that will fit.
    My first thought is linear actuators. They're easy to use, and sturdy. I could mount the keyboard to it, mount the actuator inside and I'd almost be done.
    Few problems. There usually over $100 (again bad week for this) and they're too strong. I don't need 200+ pounds of force trying to launch my keyboard through my dash if it get's hung up.
    I start rummaging through old CD-ROMs. Found one mechanism that would have worked perfectly except for size. I cut and trimmed and cut and trimmed and it almost worked. Due to the 3/4 inch height I have to work with, it would have to be almost behind the hvac controls. So know I need about 11-12 inches of straight back. So that's out.
    So I decide to make my own actuator from cheap parts. I get some 3/16 rod, some 10-24 threaded rod, nuts, some spacers and some lego parts I had around (I got a ton of the axles and what not for playing with electronics. I think I'm the only person who got their first lego set after the age 30.) The motor was a cheap one I got at Radioshack some time ago.
    Here's a pic of most of it. The middle threaded rod (which moves the keyboard) doesn't have the coupling in this pic. It looks like crap because I used hot glue for the test runs. But it works, even when barely glue together
    The two lego axle holders (or whatever they're called) have two pieces of 3/16 rod epoxed to them. These have #10 spacers on them. These slide back and forth and keep the keyboard level.
    There's two other screws holding the lego parts together. The middle rod is 10-24 threaded. I took another spacer and threaded it. This is what the keyboard get's attached to and what actually moves it.
    Takes about 2 seconds to extend or retract the keyboard.
    So know I'll start threaded the connectors and what not to make the connections permanent. Need to make a motor mount. Then I just have to wire up the brain, trim my radio brackets and hinge the center console and call it a day. I'll probably use a PIC for the controller. Kind of overkill, I know. Not decided on if I'm going to use switches or current detecting to determine end of travel.
    I'll post more pics and some vids of it in action when I get more done.
    GE Cache Builder | [email protected] |Coolstuff :autospeed.com | bit-tech.net | Nitemax Ultra Pinouts
    I know what you mean
    yup
    Please do.
    So how is the motor connected to the threaded rod exactly?
      It's going to be with a set screw, I'm going to get a smaller piece of tubing to reduce the spacer to the motor spindle. But for the tests, I just used hot glue which made me feel pretty damn good about the setup seeing it held. I need to expoy a spacer on the other end of the threaded rod as well to silence it a bit as well. The threads hitting the lego make a bit of noise.
        this is awesome! keep us posted
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
          Wow! That's awesome... Keep us updated, when it's done you should try to take a video of it in action if possible... Even if it's just a low-quality webcam or something.
          Zen Fat Loss
            Thanks. As far as vids, You can count on it. If I can find my damn taps, I'll probably have it all put together today (minus the brains). So I should have a vid of it running (out of the car) in the next day or two.
              Nice work! An 8-pin PIC would work well with the limit switches. It would be small enough to attach to the side of the motor. Like RS3RS, would love to see a video of it in action.
                Thanks. I'd probably use a 16fxxx just because I have twenty or so of them.
                What I'm going to do for the moment is wire it to a 3 pos switch and use some normally closed pushbutton switches for the limits. My main concern right now is to just make sure everything works. Play with fitment, etc. When I get around to actually installing it, I'll figure out how I want to drive it. I'll probably use a L293D as I have some on hand.
                  Well I started thinking about how to mount it when I realized something convenient. The mounting holes on the motor are perfectly aligned with Lego axel holder.
                  As soon as I can find my taps, I'll disassemble the motor and thread the holes with 10-24 threads. Use 2 #10 spacers to fill the gap and use 2 bolts to hold the motor to the mount.
                  As far as mounting the drive shaft to the threaded rod, I decided to dig around the hardware store next door and quickly found these nylon tapits. (Not sure of their proper name.)
                  It fit the shaft perfectly so I cut it down and pushed it into the #10 spacer. Nice snug fit so I'll probably go this way instead of trying to make a bushing to reduce it. I may revisit it later if it doesn't hold up in practice. So know I just need to find my tap set and tap and thread some holes and the mechanical will be just about done.
                  BTW, I believe this is the motor. I bought it quite some time ago and discarded the packaging.
                  Motor @ Radioshack
                    Ingenious! Sometimes using found parts is much more satisfying than paying for a bunch of engineered stuff.
                    BTW, I still got my Legos, too.
                    Want to:
                      I'm suprised it's coming out as well as it is. Nice monitor install btw. I'm going to co-opt your idea and combine it with my own
                      Instead of having the lcd hiding my gauge cluster, I'm going to shrink the cluster and mount it to the lcd (wrapped up in a nice bezel). So I'll have stock gauges but with the press of a button, the screen will raise, hiding the gauges and presenting the LCD.
                      With the sail servo, does it have to stay on? I would think so or wouldn't you have motor slip?
                      Lego's are pretty cool, unfortunately the only building toys I had when I was a kid were lincoln logs. I think my parents didn't want to deal with another 2000 things lying on the floor.
                        An update.
                        I have it pretty much done and it works
                        I need to refine a few things. I've got a thin fiberglass base for it to mount to (drying now), to avoid torqueing the assembly. I need to make two new sliders and a new center acutator. These are too thin. I've tapped them to mount the keyboard and it works, but it's only a thread or two. I'm going to pick up some bar stock and make thick ones tomorrow with lots of room for tapping.
                        I need to cut the drive shaft down and smooth the very tip with epoxy. The threads hitting the support make too much noise. Other then the, looking pretty damn good. I'm thinking of slowing it down. It takes a little less then a second for it to hit full extension. I wonder how much it could move with a better motor. This one is fast, but doesn't have a lot of torque.
                        So everything should be done tomorrow or Sunday, I'll be posting pics and vids.
                          If you could get some rubber between the motor and the screw you could reduce
                          the noise. the cnc guys isolate their motors from the drive screw with rubber hose as a coupler. some rubber around the mount would help too.
                            I've read that. You would think it would slip though? I may give it a try, but the majority of noise is coming from wheree the thread hits the far side. (Were the screw is hanging out in the pic). I don't mind a little bit of racket, it only travels for a second and it wouldn't sound right without a little whirring
                              How is this coming along?
