Screen placemnet in Jeep wrangler
    Right above the charred remains looks like a great spot.
    Mazdaspeed Car Computer
    gotta redo it all
      Some armour all and a little elbow grease & that will buff right out.
      •Micke
        Pick off all the bits of plastic and melt it in acetone and then mold in a large 10.4" LCD. You will need phidgets to replace those melted aircon dials and it looks liek your ciggy lighter wiring may be damaged so you may as well run the screen off your PSU.
        And while your are at it you might want to retrim those seats as they looka bit worse for wear and get e momo sterring wheel.
        You could also put a 7" LCD behind the sterring wheel so you can see how fast you are going and what revs you are doing but you had better check to see if the ODBII sensor is still in exisitance first.
        Looks like it will be a great project but make sure you run a fused 8 gauge supply to your PSU as you don't ant to cause any wires or nuthin.
          SEARCH!!!!!!@!@!@!@!@!! this has been discused before, see the burned out jeep installs in the completed projects!
          My Install
          Software:
          CFiG v1
          iGuidance Plugin for CF
          CarShell
          Working shell for a CarPC
          StopWatch
          StopWatch plugin remade for centrafuse RC1
            My thoughts exactly...
            Renault Megane...the OEM look
              I just ditched my crispy Jeep, had I known someone else was ever going to want to do another melted Jeep I would have saved my custom (and perfectly color/texture matched) mount for them. Shipping would have been cheap!
              Dashboard Install?....I don't have a dashboard?....Whats up with that???
              Would You Do Jesus?
                wow umm i think u shud send me ur screen and ill make something for u inside of my car :-D and u can tell people its ur car hahah
                  Originally posted by Enforcer
                  Can anyone help me with a location for a 7" LCD screen in a Jeep Wrangler?
                  Have enclosed picture if that will help
                  thats a Cherokee not a Wrangler
                    no it was a Cherokee, now it has the creature comforts of a Wrangler.
