Bondo..... Which One?
  • Bondo..... Which One?
    Ok I have just recently run into this problem... from this point and earlier i have always been using the bondo all-purpose putty, because thats what my local store carried, but recently they have started to carry bondo autobody filler.... which one of these is the correct one to use?
    Debating on installing a carpc in my Jeep.....
    I think the automotive one is better. That's what I'll be using!
    Renault Megane...the OEM look
      well....first off bondo is a brand......so its kinda hard to know what product you want. Typically the word bondo is associated with body filler and fiberglass/body filler mixtures. Most people start with fiberglass resin, then put a glass/filler mix on top of that, and finish it off by filling tiny holes with lightweight filler. So to answer your question..."which one?" the answer is more or less all of them. However a lot of people just go with 1 glass/filler mix.....i've used bondos "fiberglass jelly" which is pretty easy to use and with enough sanding its all you need.
      secondly, from what i've heard, bondo is actually one of the crappiest autobody filler manufacturers, but because of their emense popularity most stores dont carry anything else.
      PC Components:
      My work log
        Bondo or similar products should only be used as a skim coat to fill-in pinholes and sanding scratches. It's not reliable to use as your main compound to blend a factory trim piece to a LCD bezel. It will eventually crack and separate. There are better products out there that will perform better altough at a higher cost. I like Duramix 4040 the best. It applies easily (with special gun), sets up fast and sands easily. You can then use a glaze or putty designed for plastic repair to fill-in pinholes and scratches. These products are a lot more expensive but the end result is much better and more professional looking. Here are some suggestions.
        Main blending/filling product:
        Duramix 4040 (http://www.handsontools.com/store-pr...t%3E_9505.html)
        3M Automix 5883 (http://www.handsontools.com/store-pr...t%3E_3876.html)
        Liquid Plastic
        (http://hzemall.com/online_store/onlinestore.htm)
        Putties/Glazes:
        3M Piranha Finishing Putty (http://www.handsontools.com/store-pr...t%3E_4281.html)
        USC Blaze Glaze Finishing Putty (http://www.handsontools.com/store-pr...E_9594770.html)
        SEM Polyester Glaze (http://www.handsontools.com/store/sh...roduct_id=9063)
          I'm been using the carmix platic repair and let me tell you that it a bargin compare with other fillers that don't that stick hard... you pay more but on the long run you don't have problems.
          RexBruMet Skin for FrodoPlayer
          Nissan Aux-in MOD
          Originally posted by bgoodman
          We're an international forum, post in whatever langauge you like.
            Actually that statement is only half true. While the end result may be much better in terms of strength the end result will look exactly the same. The proffesianality is due the the person who is doing the body work regaurdless of the filler used.
              For Duramix 4040 (these stuff is expensive especially with the gun) you can use this product SEM: Bumper Repair #68422. These 2 are very much the same but SEM is much cheaper and you don't need that "special gun".
              For ABS plastic, you can mell them yourself. Check out one of the thread regarding to that stuff in this fab forum.
              Y2K Accord Dell GX150
              EmoRebellion is a SCAMMER
                That's a given. I think most people already know that the skill of the person doing the job is the most important but my point is limited to the context of the forum - plastic dash trim work not auto body work. Initially you could have the same looking results but what about a few weeks or months down the road when the lesser quality stuff starts to crack, chip and separate. Doing a professional job is more than aesthetics and what you see on the surface.
                  I think that there are higher and lower quality fillers but i dont think that the filler is really that important, More so the bonding agent. If you ensure that your bond is good and there is little stress the filler you put on makes little differnce. THe only bondo that i have had crack (the regular bondo) is when i lost the bond due to stress and a bad epoxy job. It wasn't ABS on ABS, i neglected to sand down the paint on th lilliput bezel. Under stress the epoxy gave way leading to a crack in the filler.
                  The filler is just that a filler not meant to be a bonding agent. When done right you can have the exact same result as using one of the more expensive plastic mixes. This is my point.
                  In that respect you can also have the exact same bond and the exact same bond at a fraction of the cost by using ABS chips and the solvent method. That way the two peices actually melt together.
                    I use rage gold
                      Body filler is meant to be used as a filler not a glue. More important then the product is the application. Even the best product will yield poor results with improper application. It is very important to get the right mix ratio and to mix the two part throughly. I use one speader to mix the two parts and another to apply the filler. But as mentioned by antimatter.....if what is below the filler is not solid the filler will not work properly.
                      As for products....anything from Rage is the bomb.
                        I think Rage is an Evercoat product.
                        Fabricator
                          Yes Rage is an Evercoat product. There is Rage standard Extreme, and Gold. All excellent products.
                            Whats up with their prices? $5 for an led?
                            Car Mods
                            -no car mods
                              SickVette -- where in wesley chapel do u get that Rage Gold stuff?
