custom metal work?
  • custom metal work?
    Does anyone know of a place that will (or can do themself) some custom metal work for me?
    There are no local shops that will do a little order for me.
    I need some plates made. They are about 7" x 2" and can be thin (they are mostly decorative. One needs a large square cut out, the others need some holes.
    There is nothing complicated or fancy here. But I can't do it. Can anyone gelp me?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Hey,
    There are two things I'd try if I were you:
    1) I'm not sure why you're not able to do it. If the pieces are fairly simple, you can use a nibbler (available at RadioShack for $12.99) and it's REALLY easy. You just drill a 3/18" hole (IIRC that's the size) and start nibbling. Buy the metal sheet from Lowe's or Home Depot
    2) Use eMachineShop (www.emachineshop.com)
    Jason
      ...or 3 use www.frontpanelexpress.com (aluminium only) MUCH cheeper than E-machineshop if you want just plates with holes and squares!
      Time displayed in a different way!
      http://www.lares.dti.ne.jp/%7Eyugo/s.../03/index.html
      http://www.humanclock.com/
      FREE 3D Glasses: http://www.rainbowsymphony.com/freestuff.html
        I don't know about 2 or 3, but let me tell you, 1 is not easy, does not give clean cut and takes forever - unless I don't know how to use it. I think 2 or 3 is better option if you are looking for clean cut.
          Used 3 quite some times (their European service) and the results are perfect. Dont know about e-machine shop but they have a $15/part minimum where frontpanelexpress has a $5/part minimum.
          Dont bother with 1. Will not be very "decarative".
