Is Epoxy sandable like Bondo?
  • Is Epoxy sandable like Bondo?
    I'm getting ready to modify a single DIN pre-molded radio bracket into a double DIN enclosure.
    The attached picture is what I'm working with (by the way - I HATE autotoys). I'm going to first close off both front pockets (the DIN spot and the pocket) with a piece of ABS Plastic that I plan to cut to the size of each hole and epoxy it into place (with Plastic Weld).
    I want to eventually sand the dried epoxy and cut the new 2-DIN holes. Than, I would bondo, sand, bondo, sand, primer, sand, primer, paint, paint.
    Is this a good plan?
    -HD
    epoxy is alot harder than bondo, still sands just more work!
    But IMO epoxy sands better (not easier) because its harder to dig a hole in like bondo.
    Still Planning and Scavenging Parts ------Software-----and anything else i can lay my hands on!!! :)
    Acquired a Toshiba Satelite 4000CDT
    HDD`s ****ed new one on way! 30gb Toshiba.
      Yup, epoxy is sandable, never tried bondo so don't know how it compares, but I did my entire piece with epoxy and it turned out great.
      Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
      GET PAID TO SURF THE INTERNET
        Great! Thanks guys!
          automix plastic repair is very easy to sand.
          RexBruMet Skin for FrodoPlayer
          Nissan Aux-in MOD
          Originally posted by bgoodman
          We're an international forum, post in whatever langauge you like.
            You can get something called "finishing epoxy" made by z-poxy, it sands easier.
            e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
            sold it all... :-(
            Coming Soon - 2007 BMW 335i UMPC install
              I think you can also add filler (microballoons) that might make it easier to sand as well. Altimat would be the authority on that one though.
                Yup thats all bondo is - polyester resin with Microballoons (or in the case of Bondo brand - Talc ) added to it.
                Fabricator
                  Thanks for all the suggestions. I began chopping up the radio bracket pictured in the first post tonight. Funny thing is, once I dremel-ed out the pocket, the mounting tabs and a 2 mm sliver of the top, everything fits nearly perfectly. No need to weld in a piece of ABS and dremel out the appropriate hole.
                  The 700IDT I have is a little wider than my radio so, as you can see in the picture, it all works out very well (since the radio pocket is wider than the 1/2 DIN pocket). I just need to apply bondo, primer and paint this weekend. I'll return the Plastic Weld and get my $5 back. Wish me luck people!
                  -HD
