**Alpine WHITE 4DR E46 BMW**
  • **Alpine WHITE 4DR E46 BMW**
    Just wanna show what i got so far....all custom by ME
    still got some work to do. But here are some pictures for those to see.
    I am looking for a good GPS unit and software. So far, i decided on getting iGuidance 2.0 since i've heard good things about it to use in the STATES. Also, i would like to have internet access in my car, but have NO IDEA on what to do. someone help?
    What i am looking is to finish my MOLD/DASH.
    OEM piece i have to MODIFY
    FITTING THE LILIPUT
    EPOXY AND BONDED for TEST FITMENT
    TRUNK SETUP with CARPUTER
    Specs:
    Yellowtop Optima
    (2) 12" Alpine TypeR
    (2) Alpine Class D AMP
    Alpine 6.5 TypeR Components
    Carputer: 7" Lilliput TouchScreen, Epia M10000 mobo, OPUS 90W (would like to upgrade to 150W ), 512MB kingston ram, slim DVD w/15ft IDE cable, 120GiG HD, usb Floppy, Radio Frequency Keyboard & Mouse
    PIX OF CAR
    That looks sweet. The trunk setup, in my opinion, it's an excellent choice. I've heard that combination before, and it absolutly blasts!!! Did you see the sticky in the Fabrication forum for a BMW bezel?
    Renault Megane...the OEM look
      yes i have...im trying to use that as a guide...but DANG!! this is Time consuming because its my first time making something like this. I HOPE it turns out nice
        I hope so too!
          your going to need to chop the top and bottom of the lili's plastic case to get it to fix in a way that is factory looking... I chopped my xenarcs case right down to the actual LCD panel on the top an bottom, and was able to fit a DVD drive...
          check it out...
          http://www.mp3car.com/vbulletin/show...threadid=48614
          I started with the same DIN adapter, similar to the way you did...
          I built a wood frame to recess the screen so I could lower it 2mm to make room for the DVD, since the e46 opening is shorter than the lcd panel and dvd... It actually ended up at the perfect angle for the driver and to block sunlight/glare...
          e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
          sold it all... :-(
          Coming Soon - 2007 BMW 335i UMPC install
            wow thanks i just need to get the I-bus to work when i get my new steering wheel
            have u gotten that to work?
              yep, I use the RR (road runner) modified i-bus software, works great, I couldnt do without it... I found myself hitting the buttons on the wheel before I installed the i-bus, and it bugged me to death that it didnt work... you just kinda expect it...
              just search "RR i-bus"
              sold it all... :-(
                Is that your computer in your trunk next to your subs?
                Any issues with vibrations messing with your hard drive?
                Jeep Grand Cherokee Laredo
                Kenwood X790 x/ iP500 Ipod Interface
                Elemental Designs 13Kv.2 D2
                CDT ES-620 (omg yayay!!!1)
                NINe.2X, NINe.2
                  Most harddrives can take non-operating shock of 300g's. When operating, many can take upwards of 40g's.
                  If anything in your car ever experiences 40g's of force, you got more issues to worry about than your harddrive crashing.
                  99 ram 5.9 turbo
                  P4 2.0, MicroATX, Audigy2nx, Monster Cable / Alpine.
                  Coming soon: Indash motorized, 5.1, dvdrw, gps, bluetooth, wifi, and more!
                    yea...that's my computer in my trunk made of plexiglass...as for my subs hitting, no, my hard drive is ok i think...dont notice any performance loss or anything like that.
