Location?
  • Location?
    Hi,
    I think I may have posted this before, but my comp crashed, and I can't remember. Just wanting to get your opinion, and if someone could photoshop it in, that'd be sweet. In the middle, right where the recess in the dash is ,there is loads of dead space. Thinking of starting the screen just above the wood and continuing as far up as I need, with a hood and then a fan in the back of the hood to keep things cool
    Second opinions, please
    L
    1996 Volvo 850 T5 CD - Eventually I'll start....
    22 views...no post?
      A picture form the fron would make things much easier, also some measurements would help too, so the result would be closer to reality.
      What car is that?...besides HUUUGE!
      Renault Megane...the OEM look
        Lol I know, only trawling the net for as good a one as I can, before I get it back within the week (service). It's a Range Rover V8. And it is massivley immense for Ireland. But then again, I need space to carry bikes/guitars/amps etc
        L
          I think thats a perfect position for it. Most folks put the LCD where the radio is, and as fantastic as the installs look, if the thing is below the wheel, you cant watch the road with your peripheral vision.
          In my opinion, for things like GPS you really want to be able to have the screen up near the window so you can do the quick glance at your system without totally looking away from the road
          1995 SL stock
          Working On: GMAT
          Given Up On: Custom motorized lcd
            OK - found a pic that gives a better angle
              I think I'd move the AV controls somewhere else (Maybe where one of the vents are) then create a custom fabrication to have a screen where the AV controls and current Headunit are.
                That thing is screaming for a flip/slide up screen between those cup holders or a semi molded screen that is above the vents and sticks up above the top of the dash in a nice molded surround. Like the Mondeo at the UK meet the other month. (anyone got a pic of it? I think i sent one to cris)
                  I'd go along with what Scouse says and put it where the coin tray is. Aren't those 'cup holders' air vents? A nice flip-up screen would look great there especially if you could motorise it. Nice ride btw, I used to have one of those babies but got cheesed of with 15mpg! Mind you, my right foot was probably responsible for that.
                  Only true postwhores remember everything they post
                  REP CLUB IS DEAD
                  LONG LIVE REP CLUB
                    Yup, they blow hot and cold, pardon the pun! Heh, they are nice, and you certainly get moved over for and become the object of envy at school. 15MPG is being solved with LPG - seems like a wonderfuel, provided and anti-backfire valve is fitted. Um, there are two metal bars under the coin tray which would make a GREAT base to anchor the screen and then to fabricate the hood/surround around! You get many 16 year-olds fiddling with this stuff?
                    L
                      (sadly, I can't recess it down into the dash too far, the heater pipes are down there. About 4" maybe, which'd be great - start it just above the clock
                        L
                        Erm, well there was this girl once..........Oh the joys of owning a Range Rover!
                        REP CLUB IS DEAD
                        LONG LIVE REP CLUB
                          sorry for triple-posting, but I think this'd work very well
                            That looks ok. Are you thinking of putting a cowling over it?
                            REP CLUB IS DEAD
                            LONG LIVE REP CLUB
                              Yup, like recessed in a bit to stop light from the windscreen getting at it. And mounting a fan in the cowl to clear the heat out the back.
