Vectra C Dash Part2
  • Vectra C Dash Part2
    Hi Everyone,
    been busy getting everything in the car. Almost there now
    test fitting the screen into the dash.
    the hole in the top right of the housing is for the IR for the screen
    I'm still not 100% happy with the housing still needs some work.
    Computer in housing (need to get some carpet the same colour)
    Computer opened up
    comments welcome.
    Regards,
    RichPu
    Specs.
    Asus A7S8X-MX motherboard, Sempron 2600, 512Mb, 80Gb Hdd, Onboard VGA-Sound USB GPS U2, USB 54Mbps Network, USB Bluetooth, USB Dlink radio, USB mini keyboard, M1-ATX, LinITX Touchscreen
    That screen looks awesome! Could you post another pic of it, it seems a little off in the top left corner there!
    btw, is that pc location ventilated?
    Renault Megane...the OEM look
      that pc looks awesome
      but yeah dril some hole sin the side and vent it
      put a fana nd when u get carpet just punch the carpet a buncha times before hand to make sure its ventilated.. u dont want that over ehating.. and have it blow out! lower the amoutn of dust
        Most trunks are ventilated, some even allow the ac to enter in the trunk, like the VW Bora/Jetta for example.
          There is a vent right next the computer, behind the second metal skin,which vents to the outside, and has rubber flaps that seal when there is no air movement
          there is also a 6 inch fan on the right hand side of the housing.
          I will take another picture tomorrow showing it.
          as for the screen being low on the left hand side, this was a rough test fit and the screen needs a bracket making to hold the screen housing up for a better fit.
          here is another picture of it.
          RichPu
          Specs.
            Nice PC placement! And that screen looks great.
            Zen Fat Loss
              RichPu
              That looks absolutly fantastic! Great job man! One more pic please, of the whole dash! You're the first one to put a screen in a Vectra C like that! Did you use the front from the stock HU, or did you make another one?
                Hi Cris,
                thanks for the comments. makes all the hard work seem worth it...
                I used a replacment facia for a 1 din head unit like the one below
                you will see I stilll have the original HU in the pic below
                and another better pic of the dash for you
                (will look better once all the wires are actually behind the dash)
                Regards,
                RichPu
                Specs.
                  Hi Cris,
                  Regards,
                  RichPu
                  Well congratulations! It's definatly worth it! Fantasitic job! Any pics of how you made it?
                    Hi Cris,
                    there are some more detailed pictures in this thread.
                    http://www.mp3car.com/vbulletin/showthread.php?t=51108
                    regards,
                    RichPu
                    Specs.
                      Hi Cris,
                      regards,
                      RichPu
                      Well, I remeber that thread now...it fitted nicely after all.
                        Whats the PC hardware BTW... and the PSU ?
                        Terran
                        My Project Site
                          Hi Terran,
                          the spec of the PC should now be in my sig
                          Regards,
                          RichPu
                          Specs.
                            Hi Richpu,
                            Sorry for digging up such an old thread! I have just purchased a Vectra C and am interested in installing a car computer. Congrats on yours - it's fantastic! I was just wondering if you could post some more details on the wiring side of things. The putting together of the computer and the screen is no problem - it's the connecting it to get power from the car and wiring the computer from the boot to the dash. Anything you could post would be really helpful. Thanks!
                            Jer
                              Hi,
                              The main power for the PC was taken from the main fuse box on the nearside of the boot using an M1-ATX. as for the cabling for the screen etc, this was run down the offside of the car, under the trim with the carpet, there are cable run boxes under the carpet that these were fed through.
                              the main cables were the VGA and USB cables which were both 5 metre
                              the USB was 1 cable to a 4 port hub, this runs the touchscreen, Keyboard, Bluetooth.
                              let me know if you need more detail
                              Regards,
                              RichPu
                              Specs.
