Pc case made from hardboard
  • Pc case made from hardboard
    I am making a case for my mobo/pc components out of hardboard ... and i was just wondering if anyone had any ideas for a better way of attaching the sides of the hardboard (to the other pieces of hardboard)...
    currently i am just using metal hinges... but they arent too strong..and are kind of expensive if i use alot and make it more sturdy... im looking for a cheap, compact, and sturdy way of making a case out of hardword... without having to make it any larger
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    use blocks of wood and screw into them or possibly buy aluminum L pieces and cut to length
      hmmm yea , i was thinking about the blocks of wood... except i think i already made the pieces of hardboard too small for anything that big.. (meaning the bottom piece of hardboard is only slightly bigger than the mobo itself)
      i might try that.. but if anyone has any other ideas, feel free to help me out
      AT mobo
      Linksys NIC
      Irman
        use thin aluminum L sections on the outside of the wood.give it a stronger edge, tidy things up, and its cheap. To fasten it - your choice of glue, screw, bolt, rivet etc.
        92 Subaru Legacy Wagon
        Epia MII12000 :D
        Morex 80W
        120G External HDD
        16x2 Charater Display
        Creative IR Remote
        VIA Sereniti 2000 Mini ITX Case
        7.2Ah SLA Tank
        PCMCIA 802.11b
        256DDR Ram
        Diamonds are for girls- wise men follow the stars
          what type of glue would hold aluminum (or steel?) to hardboard?
          AT mobo
          Linksys NIC
          Irman
            i dont think there would be a good way to glue it unless you drilled holes in the hardboard to allow for more surface area. If you do that, than just use epoxy.
              supposedly that gorilla glue is good for metal.. try that junk out.. $5 at homedepot or lowes or whatever.
                so your saying in order to use epoxy, i should first drill holes in the hardboard where i am going to attach the L brackets? Or instead of drilling holes to be used with glue, i should use epoxy?
                AT mobo
                Linksys NIC
                Irman
                  Hmmm. things i would try - but would depend on the size of the L brackets. Say if you had 20-30mm+ overlap then i would try araldite, epoxy, or some sort of contact adhesive. If you were going to glue - i would hit both surfaces with a 100-200 grit sandpaper. Also - with glue - a screw or two of some sort may be a good idea
                  Epia MII12000 :D
                  Morex 80W
                  120G External HDD
                  Creative IR Remote
                  7.2Ah SLA Tank
                  PCMCIA 802.11b
                  256DDR Ram
                    I recommend Home Depot.
                      The Gorilla glue expands like crazy when it cures and makes a horrible mess. You'll find out exactly how well it sticks when you try to clean the excess off.
                      Fabricator
                        sounds like a plan,
                        ill see how it works and post if i have any problems
                        AT mobo
                        Linksys NIC
                        Irman
                          Is that an ISA SLOT??!?!
                            go to home depot and get some aluminum L brackets drill into them then tap the holes you drilled. you can then screw directly into that. (use a lock washer or loc-tite just in case)
                            New System in progress:
                            M10k
                            Phaze TD1500 ~> Seas g18rnx/p
                            Zapco Ref 500.1 ~ 12" tc-9
                            Transflective Xenarc
                            My Car Pc Install
                            My Boat Pc worklog
                              Watch the specs of his carputer. ISA slots weren't uncommon back in the era of Pentiums 233mmx.
                              I too have an isa slot on my ol' trusty kt7133A
                              A box made with hardboard ? Yep, I plan using something similar, excepte the box is a tiny tool box
                              Now Galileo is real. Muhahahahaha :p
