LED display in Rear view mirror
  • LED display in Rear view mirror
    Hello all,
    This is my first post,but I have been lurking a while.Thanks for all of the useful tips by the way.
    So to my question. Is anyone familiar with glass etching techniques or other ways of possibly turning a rearview mirror into a partial display. The feature comes stock in many cars and often displays temperature, direction, or time. I was interested in extending an LED display from a radar detector to the mirror keeping it low profile and also easily viewable. I've thought about potentially replacing the mirror with a stock mirror with the appropriate display space, but it seems to interesting an endeavor to not attempt on my own, and I like the courtesy light attatched to the stem of my rear view mirror. Any suggestions would be much appreciated. Also, If there is a dim feature on the mirror that means it acts on some sort of prism which refracts the light so would the front glass on the mirror be somewhat like a two way mirror. If so then there's not any need for etching, just a display bright enough to show even when brightlights or sunlight hit it.
    Thanks,
    dan
    P.S. here's an example of what I mean. http://tunertricks.com/blog/gallery/?album=radar&img=5 ...Thanks again
    soundsdo-able , maybe you can just scratch the coating off the rear mirror
    led bar or digits?
      just search ebay, there are loads of them. they have composite input. someone on here has one. They would be very good for putting GPS directions and speedcam data up on. as well as rear view camera (using IR LEDS for night vision )
        Thanks for the responses guys. I looked around E-bay, I want to keep my Saab 9000 Mirror though and everything else seemed a bit gaudy. By the way, the led's are a display removed from a redar detector and extended up so that it looks like a stock compass rather than a radar detector, which happens to be illegal to use here. Also I considered possibly molding it into the bottom of the mirror which might make a bit more sense. Here's an example of the look I'd aim for. http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting ...this would be of course without the controls. But it might be interesting to relocate my lilliput controls there, of course losing the dim feature, and that also gives me a plastic frame of sorts to begin construction. I'll let you know if the dimensions will work.
        Thanks again,
        Dan
          Here's a thread where it was discussed. I'm still interested in trying it out and bought a couple mirrors to try it on but have gotten sidetracked putting a new computer in first.
          Want to:
            I looked around but did not find much that specifically referred to the kind of approach I'm talking about. Bugbyte, could you repost that link as it didn't seem to work. Thanks
              http://www.mp3car.com/vbulletin/showthread.php?t=46888
              Want to:
                Thanks bugbyte. Seems like an interesting place to start. Any other suggestions are more than welcome. I think I'll look into what can be done, and what some professionals have done. I'll bring back any new info or progress as I go. Thanks for all your help guys.
                  which radar detector?
                  Ive seen some installls where the person opened the mirror and used a razor blade to remove the shiny coating. Once you do that it should be clear. Then you could mount your display behind that portion and route some wires. For added stealthiness? you can take some mirror tint and put it behind the cleared portion. This will give the rear view mirror a more uniform appearance. The only thing you sacrifice if you do that is some of the light output from the LEDs. Good luck!
                    Just take the mirror glass out and get a glass shop to cut you a couple samples of half, 3/4 or whatever different kinds of half-silvered mirrors they have, figure out what kind of look you need and use that..
                    mind you, that little lever you flip the mirror up with when car headlights behind you are too bright won't work unless you get the right kind of glass..
                    good luck!
                      Tred, Where have you seen these installs. If it was online I'd really appreciate links. That seems like where I was going with this, and I'm still looking around for a detector. I'll probably go with an escort passport, or a valentine, haven't officially decided. The valentine display is much more intricate and thus would take much more work to create the display. On the other hand the passport does not have a flat display face. We'll see. But thanks for the advice and any links you can provide.
                        I would get the Valentine one with the remote display. The remote display can be taken apart to help fit inside the rear view mirror. Im having trouble finding the thread where someone did this with their V1. It may have been taken down for some odd reason. I will post a link if I find it again.
                          Dan,
                          Making a "window" in your mirror is a realatively easy process. Once you have your mirror glass removed and in hand you will want to use a small razor to scrape away the heavey "painted" backing (usually black or gray). This will expose the back side of the reflected "silver" surface. This reflective material can be removed with a pencil eraser. Note that anywhere you scratch away the backing "paint" your eraser strokes will remove the silver finish and make a "hole" in the reflective surface. work slow with your razor for a perfect edge and work even slower with your eraser and you will have a great finish. I typically use an electric eraser (drafting type) and a gritty ink eraser stick to work more quickly at removing larger areas. Hope this helps! post pics of your process!
                            Bman, awesome that's exactly what I was looking for. Due to a timing chain issue this install won't get done for another month, during which time I'll be replacing a whole lot of engine components and machining it for an overhaul. Can't wait. But, as soon as it's done, I'll bump this post again. One last question. If I get rid of too much mirror backing, is there anything I can do, such as apply a similar paint backing, to replace where i've gone too far. Thanks again guys.
                              Negative! Use some masking tape to help you keep that clean edge. You might snatch up a 12" square mirror at your local Home Depot or similar hardware store to practice on. This will help you get the process down before you go tearing into your rearview. Please keep in mind that my experiences are with standard "household" type mirrors and not automotive rear view mirrors, although I can't imagine them being any different.
