TVIEW fab help
  • TVIEW fab help
    The tview screen just simply pulls out from the front bezel. There is no screw or anything. How do you guys keep help to the bezel? Help please. And yes I searched!
    your new friends name is hot glue :-D
      I used a T-view. I just made up some little metal brackets that basically just press the screen against the bezel. Works pretty well.
        I just put the back on and glued it shut, works pretty good!
        1990 Jeep Cherokee
        2000 VW Golf TDI 4dr
        2005 VW GTI MKIV - SOLD
          I just put it back together and added a small fan n the back
          Crazy Miami Drivers
          R.I.P. My first ever NEW Car
          Old installation
          New Install!!!
          |-------------------100%|Cables ran
          |----------------85%----|Software RR
          |--------------80%------|Complete
          [/SIZE]
            not a good idea, everything i've ever done with hot glue in a car has melted and fallen apart. When I took my explorer down to SC, it was like 115 and my composite lcd (no carpc at the time) sunk back behind the enclosure i made for it.
            PC Components:
            My work log
              I second the hot glue issue, I use it in my case to hold my mobo in, and my hard drive. Needless to say hot glue melts at a pretty low temp and will not work to well.
              Screws and brackets my freind. Use the head rest enclosure it came with as well. IT will look good, give you the ability to remove the screen (in case it dies or you upgrade) and will make life easier...maybe
              You can still have something if you have nothing
                There are high temp hot melt glues.
                Fabricator
                  no cover
                  look at my photos the original case is unused
