100% ABS LCD install with texture
  • 100% ABS LCD install with texture
    Figured i'd post this here to help anyone interested in molding their LCD into their dash using only ABS plastic, since it won't crack due to temperature variations, and different expansion of dissimilar materials (ex: bondo over ABS, etc.)
    First, I bought some 12"x12" ABS sheets from Mcmaster.com:
    then I cut a sheet so it fits in the dash:
    Then ripped apart my Lilliput 8", and cut off the lower part with buttons using a jigsaw:
    Then sanded the paint off the Lilliput bezel to get my ABS goo
    which i'm using to weld all my ABS pieces together.
    Then I glued the Lilliput bezel to the ABS plate after cutting out a spot for it:
    Backside (detail of ABS goo):
    Then I sprayed it with Duplicolor's Adhesion Promoter for plastics (available at auto parts stores), then a light coat of SEM texture spray to get a pebble grained texture:
    Then another coat of adhesion promoter, and two coats of Duplicolor Bumper Coating (black):
    The other piece is a trim piece i built up using ABS plastic strips, and sanded to shape. Here are several pics during it's build:
    And finally the whole assembly installed:
    Worklog is posted Here
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    I like that old RF symmetry setup.......they were awsome & the first of it's kind.....do you have the 32 band eq add in board?
    what is the part # for that sem texture coating? I can almost make it out in your photo, but not complete.......I would like to play with it.....
    screen install looks great btw....
      Very awesome, love the overhang to help with the sunlight.
      2000 Sunfire build 100%, or is it ever really 100%?
        I have the 28 band eq module installed... Here's a link for the texture spray: http://shop.store.yahoo.com/yourauto...e/semteco.html
        WORKLOG
        Webpage
          oh yeah, 28 band....it's been a while, but I used these in a few installs...., thanks for the link...
            coool man, nice to see you back.
            My Carputer! (More Car Pics at the end)
            2 Kicker Comp 10"
            Epia M-9000, 256 MB DDR, 120 Gig HD
            Lilliput 7" VGA Touchscreen
            Check it out?!
              awesome man. good job. do you have the exact part number of the abs sheets you ordered off of Mcmaster.com?
                Go to http://www.mcmaster.com/ and in the search box, type in "ABS sheets", or the part #. They carry several thicknesses and sizes. I think the part # is 8586K162. I bought two 12" x 12" 1/8" thick sheets. After shipping to FL it cost me $17.
                WORKLOG
                Webpage
                  I too would like to thank you for the ABS supplier hook up. Good stuff, and I like the install. Looks really clean. This ABS "goo" you are talking about.... Is that a product or are you using ABS glue or some sort of putty ABS mix combo to make a "goo"?
                  Bob. Yes, that's me.
                  [=|=======] Hardware Aquisition
                  [|========] Fabrication
                  [|========] Software Development
                    ABS solvent adhesive thread http://www.mp3car.com/vbulletin/showthread.php?t=45050
                    Dr. Ron Paul for President 2008
                    Hope for America - http://www.ronpaul2008.com
                    Who is Ron Paul? - Why do we need Ron Paul?
                    CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
                      Awesome work, and thanks for the pics & write-up! That is a huge opening, it must be a 2.5 DIN, right??? I have double din, or maybe it is just 1.5... I am not sure after seeing that! I am looking to use this method on my lilli in-dash install, but am hung up on the fitting of it.... don't have as much room to work with as you did...
                      I am curious about the trim piece you made the overhang on... Was that the factory trim?
                      Carputer status: [-*---------]
                      Im thinking laptop...
                        nevermind... question is answered in your worklog... thanks for being thorough!
                          You can get ABS cheaper at cardomain.com --> http://www.cardomain.com/shoplist~t~Laminates . Less than $4 for a sheet of 12x12" 1/8" thick ABS. They also have 3/16" fyi.
                            great work!!!
                              That install looks great. I used the ABS solution to mold my monitor. Where can i get the texture paint that you used snootch?
                              My 2000 Accord Project
