Goose Neck Mounting Kit
  • Goose Neck Mounting Kit
    Has anyone used this type of kit http://www.etronics.com/product.asp?stk_code=powgoose22 If so could you give me some feed back on it please. Thank you.
    Originally posted by extrememc
    Has anyone used this type of kit http://www.etronics.com/product.asp?...e=powgoose22 ? If so could you give me some feed back on it please. Thank you.
    I tried, but the link you give was not found. Message :
    Sorry, the product you were looking for was not found.
    FYI, I use goose neck mounting post for my 7" XGA monitor.
      The link is fix.
        The link is fix.
        Yes, the link is ok now.
        If you need only 7 inches VGA to support, goose nect is ok to use.
        For me maybe different. I need to install another 2 (two) HAM radio transceiver display at the same place as I said in in my reply PM.
        So I should made my second Stainless steel pilar/post for my Ford SUV as I did before for my Mazda Sedan. I will take some pictures and post it here if you need it.
