Spraying trim
  • Spraying trim
    Hi,
    Some parts of my trim are plastic, which is easy to spray.
    But others are like vynil-covered...possible to spray this ****?
    L
    1996 Volvo 850 T5 CD - Eventually I'll start....
    you seemed to of answered your own question.
      It stuck, but I broke the car ages ago, so I can't remember exactly what happened.
      Sorry, My question was kinda bad. Had any experience of it lately?
        if its prepped correctly, you'll be fine. put protective clear coats over it all.
          Primer
          http://www.autoaccessorystore.com/ho...=detail&id=358
          Paint good for both vynil and plastic
          http://www.autoaccessorystore.com/ho...=detail&id=357
          2008 350z GT Installed since April 22nd 2011 - Worklog
          2000 Protege Installed Since April 2, 2005 - Intel D201GLY|Fusion Brain|ODBPros ODBII|Engenius|GPS Rikaline|Powermate|Motorized Lilli
          Sound Stage
          Eclipse|MTX|Infinity
            ta. standard car paint work?
              If you prepare correctly you should be ok, clear coats as stated above. But why not go with paint that is made for the surfaces?
              Here is an shot of what I did. There is not a single crack, fade, scratch after a year which includes temps of -30c and +35c. (Canada has some really radical temp swiings)
              The paint I used is called Krylon Fusion, but works with plastic.
              Sound Stage
                serious? I live in Ireland, **** all paint options ehre
