Attaching screen to mounting...
  • Attaching screen to mounting...
    Hi,
    about 50% through my dash build. I am now wondering how to attach the screen to the front of the case and hence, the whole build.
    I have included pictures of the screen from all four sides, and one of the dashboard. I was thinking maybe build a tray under the whole lot and have posts to hold the screen up?
    Anyone?
    L
    1996 Volvo 850 T5 CD - Eventually I'll start....
    use little brackets on the back of lilliputs they have 4 little brackets that screw onto the front bezel and hold the screen inplace from behind and then the rest of the lilliput mounts to the front like a clam
    ur post idea is cool but what if the screen goes left and right how will u stop it from doing that?
      It's not a lilliput screen. I hear you though - brackets would be a good idea. I think I'm going to cut the back of the unit down a bit, and screw that on, as it was, but just reduce it in size, so it'll fit. In the mean time, keep the suggestions coming!
      L
        yeah i know its not a lilliput screen i was just saying use something like the brakets used on lilliputs
          cool. Any chance of a pic of those? I'm sure I can put two on the bottom, failing getting the back on. Then get two clamps for the top?
          L
            The thing is, that there is circuit board and bits (you can see them around the edges) that probably wouldn't take to happily to a clamp....
              well they usualy are 2 on the left 2 on the right ill try to find a pic and post it
                http://digitalww.com/images/TouchKit...dscrewleft.JPG
                http://digitalww.com/images/TouchKit...screwright.JPG
                  Ah! I'll do much the same. The screen fits tightly into the moulding...so all is going well!
                  L:
