What filler to use?
  • What filler to use?
    I'm trying to get my screen mounted indash. I've resized the screen's housing so it fits a double din mount:
    The front of the screen is glued to the doubledin and is very solid, the back of the screen also still fits (after resizing)
    I'm kinda stuck on what filler I should use to fill the gaps between the screen and the doubledin. I'd like to fill the gaps, sand it down and spray the whole unit in the color of my dash.
    Can you recommend me a product (filler) that is available in The Netherlands, I hear Bondo is good, but it's unavailable where I live... :/
    I used this and it gave me good results (thanks altimat for recommend me this product ):
    http://stage.sherwin-automotive.com/...t=29778&cat=37
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Originally posted by bgoodman
    We're an international forum, post in whatever langauge you like.
      I reccomend this stuff x100. I use this almost daily in body shop. This stuff is very easy to apply, and sand. Regular bondo is extremly heavy and tedious, this stuff is a godsend. I reccomend this product hugely.
      Jeep Grand Cherokee Laredo
      Kenwood X790 x/ iP500 Ipod Interface
      Elemental Designs 13Kv.2 D2
      CDT ES-620 (omg yayay!!!1)
      NINe.2X, NINe.2
        ive heard good things about melted plastic using something like acetone... the result is easy to sand... search for the thread on here about solvents and adhesives... good luck..
          Rage Gold body filler maybe?
            I've ended up using "Alabastine Polyester Plamuur" :
            Works like a charm, just need to fill the small holes with some filling primer.
              The result of a weekend sanding, filling and spraying primer:
              *nb screen is attached with 2 screws only, thats why it hangs a bit (pic 1&3)
                That's looking really good mate.
                2Fast's Tumbleweed - Spag bol's Tumbleweed - 2Fast's site
                  very nice, my turn is comming up soon hopefully I can produce a nice look
                    Thanks for the Alabastine tip en succes!
                      First layer of paint:
                        What product did you end up using for filler? How did you keep the filler from covered the holes for the buttons? Thanks
                          [OFF TOPIC] Sorry for thread hijack, but somehow related
                          The developer(s)/site admin(s) of this site http://stage.sherwin-automotive.com...ct=29778&cat=37 (link given by thanatos106 in post #2) should give 2 weeks vacation at the beach with no paid.
                          They didn't turn off the ColdFusion debug dump. It shows every single querries run to retrieve the page.
                          [/OFF TOPIC]
                          Now that fab job look nice. Which product did you use?
                          Y2K Accord Dell GX150
                          EmoRebellion is a SCAMMER
                            Hah?
                            Am I in any danger here??
                            Thanatos.
                            Edit:
                            Very nice job with the dash trim.
                            Nissan Aux-in MOD
                              I've smoothed the small grooves between the buttons and around the screen and I was carefull not to put filler in the holes. I filed away the bits of filler that got in the holes once the filler dried. I also removed the led above the volume +- button. I forgot to take the transparant plastic out before I started sanding, so it looked like ****. I just put filler over it, sanded and sprayed it. Now you can't tell there was a button there, unless you knew it was there before.
                              Thanks!
                              As said a couple of posts above:
