89 mustang Convertible In The Works
  • 89 mustang Convertible In The Works
    Well here she is... building a glass inclosure for a 1989 mustang gt vert. have 2 kicker comp vr 10's both in a 3 cu ft box slot vented and with the trim makes it into a 4th order band pass through the ford oval in the middle. Will have the ford logal in polished backlit aluminum floating in the oval. just need to glass the shell and finish with kitty hair and rage gold. more pictures to come.. also have the battery back there as well. man this is a lot of work.
    and one more
      looks like your doing alot of custom composite work, good luck!
      My Install
      Software:
      CFiG v1
      iGuidance Plugin for CF
      CarShell
      Working shell for a CarPC
      StopWatch
      StopWatch plugin remade for centrafuse RC1
        Wow.. I want to see the progress on this bad boy. Looks like a good start!
        1997 Mustang GTS "Jenna"
        VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
          and more sanding
          and more sanding
            and more sanding
            and more sanding
              cover it in carbon fiber
              cuts down on the sanding and looks great.
              ok so it might cost you just a little.
              My Install
              Software:
              CFiG v1
              CarShell
              StopWatch
                The rest of the car
                  neat, i was just about to ask for some photos of the rest of the car =)
                  Dr. Ron Paul for President 2008
                  Hope for America - http://www.ronpaul2008.com
                  Who is Ron Paul? - Why do we need Ron Paul?
                  CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
                    drooool ... love the hood (cervini?) on that model
                      looking good!!
                      www.superchargedmiata.net - all about roadster lifestyle
                        And still going........
                          sucker is beautiful
                          Car Mods
                          -no car mods
                            That looks hot.
                            Comming along nicely
                            Got a few questions if you have the time:
                            How many hours has it taken you to get the boot / trunk this far???
                            How many layers of glass did you use ???
                              Not sure on the time factor and do not want to know... lots..... as for the layers the spare tire well enclosure has thick fleece and 2 layers of heavy mat, same with the pods that hold the speakers. It is thick 3/8 to 7/16 and super strong with no flex. Not sure on the weight of the fiberglass mat. The trim has the thick fleece and one layer of fiber glass cloth (lays on better). also has some mat in areas that needed a bit more strength and thickness. I think i have used 3 gallons of resin so far. Moving on to the custom trim for the touch screen. Will have the screen, volume controls with hot media keys and 2 usb ports from a dell keyboard(sk8135). heater controls as well. Also making a custom guage pillar to hold a 5 inch autometer tach and 2 other guages and tweeter pods. NEED MORE TIME! It should look very clean
