I just got my screen!!!! Please help
  • I just got my screen!!!! Please help
    Hi,
    I just received my Lilliput 629 7" Touch Screen and I seriously need some help!
    I have been lookin over this forum and I see that there seems to be a ton of different ways people are fabricating casings for their screens. Could some please help me with the pros and cons of the different methods.
    I have a 1997 Lexus ES 300. The center console is black plastic. I was thinking maybe i could just get a piece of that and cut it to fit the screen...
    I have attached a pic of the center console in my car. Any help would be very much appreciated!!!
    Thanks,
    slevytam
    Well you good take that top section after the climate controls, in the ducts and hazard button and relocate that else where. That would be a pretty good spot I'd think.
      As for asking what to use to fabricate. Use the screen bezzell that came with the screen. Take apart the screen and just work with the front shroud for now. You may have to trim it down some and will have to bondo to it.
      It's really hard to explain with just words. I'd suggest looking around and getting a better understanding about what goes into fabricating your screen to fit into your dash. You can also check out my web page for pictures of my screen fabrication process. It might give you a better idea about what you are about to get yourself into and give you some ideas.
      Jan Bennett
        Hi,
        Thanks for the replies... I would like to remove the cd player and place the screen in there.... It should fit without any problems I would think :S
        I will have an amplifier connected to the carputer for my sound
        Can anyone tell me where I can buy the the same type of black plastic that is used on the console?
        Thanks,
        slevytam
          it's not really something that you buy
          but you might consider ABS plastic
          why are you needing it?
          are you wanting to use that for your molding or what?
          Jan Bennett
            I was kinda thinking i could get a hold of a piece, cut holes in it for the buttons and shape it so it would find it to the console.... (Good/Bad idea im not sure ? )
            Really what I was wondering is if someone could look at my console and suggest a method that they think would be best for my situation...
            Thanks,
            slevytam
              mkay - but are you going to finish that out at all? mold it in? or just leave it where it looks like it's stuck on?
              Jan Bennett
                Originally posted by AC5JL
                I just put a 7 in touch screen in a 99 lexus es 300...
                oh *****... get back to work and finish it
                  dude.....you showed us like 4 pictures.....of nothing.....
                  ....you didnt do anything.....ok the screen is there.......but common man....open your eyes.
                  I want my bandwidth back......and the .5 seconds I wasted looking at the second 3 pictures
                  PC Components:
                  My work log
                    i think whats even more irritating is that the first and last picture are the same
                    PC Components:
                    My work log
                      Look what u did, u guys scared him off.
                      but I think u guys were a bit harsh, we was just giving a suggestion.
                      Installed
                      Asus A7N8X-VM - AMD Mobile Athlon 2400
                      512 Ram - 60GB HD - Opus 150w
                      Lilliput 7" - Rikaline 6010
                      [00000000000001100010-] 98% Completed
                      Check Out My Install!!!
