New Aluminium Case Moving Along Nicely
  • New Aluminium Case Moving Along Nicely
    This is REV B of my carputer. I added an OPUS 150 and got rid of the inverter. This saved alot of space so now I can make a smaller case. I got a hindged door with a lockable latch. All the inputs are bulkheads for easy install/removal. I got a 9 pin molex for all the power and rca bulkheads for the audio. It should be in production by the end of the week. I'm gonna take pics all through the process. First it will be laser cut and deburred. Then it will go off to the brake forms. Next it goes to assembly where the clinch nuts and standoffs will be pressed in. Next the hindge will be spot welded to the door and the case. Then it will go off to the paint booth. And finally, I will do all the final assembly.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Lookin good man! What application are you using for design? Im working on a similar project in another thread. This looks to be almost a full size ATX case though. I used .063" aluminum on mine and it is strong as can be. I would not do anything under .040" or it will be too flimsy. Can't wait to see some pics of the production and final model.
      I'm using .050 H32 so that I can use an .032 bend radius. What bend radius did you use? Its a micro atx case. Not quite as big as the ones in the stores but it will house full size PCI cards. It's a lot thinner than and shorter than a normal case not to mention single walled design to save space. It's a bit longer because I'm puttin my USB sound card and XM PCR all in the case. The software I used for this is Mechanical Desktop 2004 DX. I have Catia and Solidworks but for such simple geometries its easier for me to use MD. How about yours?
      2.4 celeron
      150 watt OPUS
      micro atx
      xp pro
      tv/radio tuner card
      audigy
      Dual monitor Radeon
      802.11G Mimo
      xm pcr
      dvd
      gps
      IGuidance
      dual optimas
      battery isolator
      15" screen
      My Truck
        The pieces are being cut today on either this laser or the dual bed laser similar to this one.
        Mazak Laser Capable Of Cutting Up To .250
        2.4 celeron
        150 watt OPUS
        micro atx
        xp pro
        tv/radio tuner card
        audigy
        Dual monitor Radeon
        802.11G Mimo
        xm pcr
        dvd
        gps
        IGuidance
        dual optimas
        battery isolator
        15" screen
        My Truck
          Tomorrow the pieces will be break formed on this with an .032 radius.
          2.4 celeron
          150 watt OPUS
          micro atx
          xp pro
          tv/radio tuner card
          audigy
          Dual monitor Radeon
          802.11G Mimo
          xm pcr
          dvd
          gps
          IGuidance
          dual optimas
          battery isolator
          15" screen
          My Truck
            Here are all the pieces, laser cut and waiting to be break formed.
            2.4 celeron
            150 watt OPUS
            micro atx
            xp pro
            tv/radio tuner card
            audigy
            Dual monitor Radeon
            802.11G Mimo
            xm pcr
            dvd
            gps
            IGuidance
            dual optimas
            battery isolator
            15" screen
            My Truck
              Awsome!!!! which I had access to that kind of machinery. Good work, please keep us updated
                yo man ur near by if u finish this caser i might be interested in buying em maybe bulk status
                  Break formed. Now it's off to assembly.
                  2.4 celeron
                  150 watt OPUS
                  micro atx
                  xp pro
                  tv/radio tuner card
                  audigy
                  Dual monitor Radeon
                  802.11G Mimo
                  xm pcr
                  dvd
                  gps
                  IGuidance
                  dual optimas
                  battery isolator
                  15" screen
                  My Truck
                    primed in military spec primer.
                    2.4 celeron
                    150 watt OPUS
                    micro atx
                    xp pro
                    tv/radio tuner card
                    audigy
                    Dual monitor Radeon
                    802.11G Mimo
                    xm pcr
                    dvd
                    gps
                    IGuidance
                    dual optimas
                    battery isolator
                    15" screen
                    My Truck
                      Painted and textured for a rugged scratch resistant finish.
                      2.4 celeron
                      150 watt OPUS
                      micro atx
                      xp pro
                      tv/radio tuner card
                      audigy
                      Dual monitor Radeon
                      802.11G Mimo
                      xm pcr
                      dvd
                      gps
                      IGuidance
                      dual optimas
                      battery isolator
                      15" screen
                      My Truck
                        Check out the pressed in clinch nuts and stand offs. They are completely flush from the back side.
                        2.4 celeron
                        150 watt OPUS
                        micro atx
                        xp pro
                        tv/radio tuner card
                        audigy
                        Dual monitor Radeon
                        802.11G Mimo
                        xm pcr
                        dvd
                        gps
                        IGuidance
                        dual optimas
                        battery isolator
                        15" screen
                        My Truck
                          wow! great work! Can you design me a custom one?
                          Jarrod - Holden VX S!
                            I'm considering making a case like this myself, as I have access to a CNC machine and a sheet metal bender etc. But i'm wondering how you do that bit? With the Stand offs completly flush from the back? Do you drill 1/2 of the metal and insert the standof inside?
                            any tips would be appreciated!
                              I made mine with regular motherboard standoffs that screw in. I used .063" aluminum, drilled a hole where it went, tapped the hole 6-32 and then the standoff will thread in and be perfect flush on the bottom
