Repainting dash
  • Repainting dash
    Several months ago I modified a junkyard dash to fit my truck and my screen. The dash was textured, so I had to fill in the stock texture with primer before I painted. After bondoing using a product called liquid plastic, I followed this procedure (I used all SEM products):
    -sand entire piece with 220 then 400 grit sand paper
    -clean dash
    -2 light coats of adhesion promoter
    -10 coats of primer
    -sand primer down with 400 grit sand paper to create a smooth surface (the primer had filled in the veins of the stock faux leather texture)
    -clean with water
    -3 coats of texture spray to create uniform texture across the whole piece
    -8 or so light coats of paint to finish it off
    The paint has held up just fine, but now I would like to repaint it as I have found some paint made by Ford that will exactly match my interior. My question is, do I have to sand everything off and repeat this entire procedure? If there's another way, I'd like to avoid the significant amount of time and materials involved, but I also want to do it right. The worse thing that could happen is I repaint it and in two more months have it start peeling. So what do I need to do?
    My 2002 F250 Install
    sand the whole thing down with some 60 and then move up and up and up thats how i did it with my bike parts and stock dash works well
      If you want do it right, you have to sand down the old paint.
      Renault Megane...the OEM look
        i have a question very similar to this *sorry if you consider it thread jacking*
        The dash in my car is a pretty soft material, probably vinyl to pay it would i have to sand it or revinyl it? and if i paint it in SEM, wont it flake if i push hard on the dash and the paint loosens??
        **edit** donde, you have a very nice dash assembly
          There IS plastic safe paint stripper; Bumper stripper works with certain plastics (melted my abs dash though so beware!)...
          I ended up using Polly Scale ELO (easy lift off) which is made for use on model trains and such, worked excellant with some steel wool! I had my "textured" paint and the krylon fusion primer off in no time. AND it didn't eat my ABS Dashboard (that was underneath) at all.
          FYI I picked it up at a local model train/hobby shop for $11.
          - ƒarrow
          www.myspace.com/farrow099
            SEM paints have a flex additive in them so they are designe to bend without cracking.
            there is a company that i used that will match oem texture and color. the company is called leather magic and they do great work.
            New System in progress:
            M10k
            Phaze TD1500 ~> Seas g18rnx/p
            Zapco Ref 500.1 ~ 12" tc-9
            Transflective Xenarc
            My Car Pc Install
            My Boat Pc worklog
              How much did they get you for? (to "leather" the dash)
              - ƒarrow
                $65 and it was an exact match, even when taking a picture (usually that shows any difference in sheen or color) it matches perfectly
                stock:
                modified:
                M10k
                My Car Pc Install
                My Boat Pc worklog
                  wow, they do good work, as do you, thats a hella nice vette
                    you sent them the whole dash ? and they recovered it or you used one of their products?
                      I was under the impression he sent in just the modified trim panel.
                      - ƒarrow
                        you are correct. i sent them my modded piece and then a sample (cupholder lid) and they matched it perfectly
                        M10k
                        My Car Pc Install
                        My Boat Pc worklog
                          im having my dash painted to match my exterior.. right now im jsut getting a few trim piecesd one to see wut it looks like.. then its onto the big boys
                            What big boys...?
                              more hijacking on my part :
                              1. Is there a way to paint the whole dash ( i mean everything) black? cause right now my is greyish and getting discolored.
                              2. Someone said i can use SEM products for it, anything else ? maybe i could dye it?
                              3. How do i know wat kind of material was used to make the dash?
                              If i get enough info i might just write an FAQ while I do it!
                              No smiley to express my gratitude
