cherokee 2 din multimedia install
  • cherokee 2 din multimedia install
    its just a basic 2 din mp3,dvd,tuner,radio unit.. I wanted to make it look factory...
    first- i cut out the bezel big enought for the unit to fit.. I even had to cut down the ac vents so it would go back far enough..
    then- after mounting the unit, I glued a wood frame around the bezel to fit,
    then, i shaped it with bondo and
    painted it
    what do you think?
    the unit has aux inputs, I would love to a have gps,, is it possible to turn a desktop pc into a car pc? i have a decent one just collecting dust...
    That looks excellent. Well done.
      looks good. to answer your question, yes, you can turn a desktop pc into a carpc.. check the link in my sig.
      Dr. Ron Paul for President 2008
      Hope for America - http://www.ronpaul2008.com
      Who is Ron Paul? - Why do we need Ron Paul?
      CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
        thanks!
        heres a close up
          wow that looks fantastic, i want one for my cherokee
            thanks, im happy with how it came out... the only thing i dont like is that the headunit doesnt save the contrast settings.. every couple times i turn it on its all outa wack, not really a prob, just have to adjust em... I may do the whole thing over but this time make a carpc setup instead..
              SPcustoms... how much would you charge to modify the center console bezel like that?
                Ill give you that exact one for 75shipped... just remember this is only a bezel, you have to mount the headunit into position in the dash and move it around till the bezel fits... That was the tricky part, i even had to cut out some of the dash innerds...
                but i am planning on redoing everything so i wont be needing the bezel anymore....
                also since the pics, I repainted it for a better match with SIKKENS interior paint....
                  That is a double DIN opening on that bezel right? No chance of the paint peeling?
                    yes 2-din,
                    ive never seen this stuff peel,
                    i did it with a good system, sikkens primer, sealer and topcoat...
                    The only thing that could damage it would be harsh chemicles...
                      SPcustoms, I just sent you a PM.
                        i joined this site specifically for this...i have been trying to get a double din in my 98 and i need a bezel...can you make me one just like yours that i can fit a double din in?
