which fiberglass to buy?
  • which fiberglass to buy?
    I want to make add my ps1 screen frame into my dashboard. which of the products in the link should I use for this job? http://www.partsamerica.com/ProductL...glass%20Repair
    i dont know what the difference is between them
    thanks for any help!
    Can you post some pics of the parts you are using? If they are all plastic parts, use plastic glue epoxy to spot weld the parts together. First spot it because if you don't get it right the first time , it's easier to take apart. Then i would use the Bondo Fiberglass Resin Jelly. It is very good for strengh. Then sand. Then use the Bondo filler. Again sand, sand, sand! If you never done this before, I would not start with out some practice. You need to know how to mix the Bondo and hardner together just right. If you put too much hardner, it will harden very fast and you won't have alot of time to work with it. On the other hand, too little hardner and it won't dry or harden. Just my two cents
      i dont have any pics, but they are all plastic. thanks for the suggestions
        do you mean Bondo Fiberglass/Plastic Filler: Bondo-Hair?
          Bondo Plastic Filler: Quart; Premium Lightweight.
            Use this first to put everything together.
            http://www.partsamerica.com/ProductD...partnumber=272
            then go over it with regular bondo to smooth everything out. and remember do alot of sanding to get it prefectly smooth.
            if you want a stronger bond, I suggest using epoxy to hold the two pieces together, then go over it with bondo.
            Installed
            Asus A7N8X-VM - AMD Mobile Athlon 2400
            512 Ram - 60GB HD - Opus 150w
            Lilliput 7" - Rikaline 6010
            [00000000000001100010-] 98% Completed
            Check Out My Install!!!
              Here is a link to lcd install, Arby did in a eclipse:
              http://www.arbybean.com/carmp3.php
              Has alot of good pics on how he did it! I saw this a few years ago, It inspired me to start my own project! Thanks Arby!
                thanks guys! now i have a direction to go
                  link?
                    Link is: http://www.arbybean.com/carmp3.php
                    Carputer: VIA M10000 Nehemiah Core, OPUS 150w - Optima YellowTop Deep Cycle battery, Netgear 54Mbps WG111 Wireless USB 2.0 Adapter, Using 'modified' Onstar box as GPS unit, 7" Lilliput put into digitalww dash kit by myself
                    -My Denali-
                      Originally posted by rulouder22
                      fyi, you do not need to use fiberglass like he did.
                      Installed
