need fabrication work done Detroit, MI area
  • need fabrication work done Detroit, MI area
    I need a alpine 6.5" touch screen installed in my center console of my 92 merc 400e where the radio currently resides. I only want the screen to be shown with no bezel like most people have done here. I can send the center console/screen to if someone is not in the detroit area.
    why not give it a go yourself?
    also, why not try local shops?
    Jan Bennett
      probably going to be costly seeing as it is a custom job.
      1.9in x 2.9in -- 47mm x 73mm
        i checked local shops and they wanted 650.00. I don't have a garage to work in currently since I just moved here and I honestly don't have the time.
          very well then.
          You might also consider hitting up some dedicated car audio forums.
          Since it's an alpine piece, there's a good deal more risk involved since those are typically more expensive than a VGA monitor like we all use here.
          Jan Bennett
            any suggestions as far as a good car audio forum
              www.caraudioforum.com
              for starters...
              google for others, there's quite a few of them out there.
              however, someone here just might be willing to help you out so keep checking your thread.
              Jan Bennett
                I tried that forum with no luck. seems more people are fabricating on this forum. I'll keep checking this thread.
                  http://www.sounddomain.com
                    I checked sound domain and no luck there either.
                      i got a buddy out in detroit with a custom audio shop...pm me for his info and tell him i sent u he should give u a good price.
                      i got dat ***** sittin on 22s! SUPERMAN EDITION!
                        He emailed me. He didn't mention anywhere in here that he wants paint or vinyl quality finish for this and only wants to spend $200 including supplies.
                          mkay.....
                          Jan Bennett
                            I replied back to you regarding the 200 and I mentioned that I was not aware how much the prices are for this type of work.
                              I guess that would explain why you bawked at the prices you were quoted.
                              It amazes me how people put a price on things before they have any idea what it takes.
                              Fabrication work is very time intensive. To make it look like it was very simple to do usually takes a LOT of time.
                              Jan Bennett
