Would this be easy to color match?
  • Would this be easy to color match?
    I have a 2006 Ford Fusion with Piano Black interior. Here's a pic easy would this be to fabricate and color match to look factory?
    Probably not too hard with the right primer, paints, and sealant. It would require a lot of sanding to make it smooth.
    I'd also look into glossy black vinyl.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
      Easy take it to a body shop or even home depot and have them scan the color and mix it up for you. Some body shops can even make a spray can of the paint for you.
        Umm, if you use interior wall paint on your car, you deserve to be shot.
        You can get a little can that you pour automotive grade paint into and there's a little butane propellant can you put on the bottom. It's like a rattle can but it's WAY better stuff.
          that black color looks to be your car's body color so an auto body supply shop is your only bet
            go to and order the factory color in a spray can and save yourself A LOT of time and $$$
              Have you tried the spray cans yourself? What kind of results did you get, id like to see pics if you dont mind this looks kinda interesting
                no matter what your paint in the car you must prime it, is the part is plexible, i would go with latex paint on the primer
                R. T. F. M
                  i've never used the cans from paintscratch, but i've used spray cans many times.
                  the whole thing with painting interiors, is like yevmeister said, you have to use a primer. then use really thin, light coats. i would use a clear coat when you're done, especially to make it nice and shiny like the factory piece.
                  take your time though, and it'll turn out just fine.
                    Even if it's not plexible?
                      DON'T PANIC.
                      Previous install pics in 2k3 S10
                      Project CarPc V2
                        english is my third language, and i am perfecting my Vodka Science degree, to Doctorolisimus of Vodka Science
                        R. T. F. M
                          Fan of many languages, master of none Where are you from?
