Method of Bonding fiberglass with ABS plastics
  • Method of Bonding fiberglass with ABS plastics
    For Search Nazis i did the search, and found few but not deep enough
    i was wondering if i could get some epoxy apply is as a layer on ABS plastic, later when i am finished with glass, would resin bond to it
    Yev
    R. T. F. M
    Duramix.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
      Out of curiosity, have you tried using construction adhesive like PL? Seems to me that something tough enough to bridge a 3/8" gap and hold things to houses in the elements might do okay in a car... just a thought, no promises.
        Originally posted by Naamanf View Post
        Duramix.
        got it so just finish the panel, that i would like to add on, some duramix, sand, and glazing putty, vynil and i should be set?
        Would regular epoxy work as well the reads "bonds plastic, fiberglass etc. " on the label
        Yev
        R. T. F. M
          Believe it or not, Ive been in the process of using PVC Cement...after it cures, it acts like a plactic, flexable but won't un-bond. Also, its fairly sandable too. Hope it helps
            SEM Plastic adhesion promoter spray
            http://store.detailandstripes.com/sem-39863.html
            2nd bottle from the left
            screen name here use to be MegaloRESE15"
              what are you trying to do? Once I know that much I can try and help some
                i will get some pics tomorrow,
                Yev
                R. T. F. M
