Where to find track sliding panels
  • Where to find track sliding panels
    hello i was wondering what is the actual name for this nifty things
    i am looking for one around 8-9 inches wide
    Yev
    R. T. F. M
    Yev
    are you talking about linear slides? can you please explain it a little more
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      Making he's thinking of something along the lines of a tambour door?
      "It's a blessing . . . and a curse."
        oh...thats what those doors are called!
        M10k
        My Car Pc Install
        My Boat Pc worklog
          yeah tambour door !!!, thank you very much for enlightememnt, although i think i will go to home depot, get some styrene, or flexible strips, attach it to the cloth, and make a track out of something, and make a DIY on that
          Yev
          R. T. F. M
            Yev, that's how those doors are made. My dad used to build custom cabinets for Gulfstream jets. There's a thick cloth backing and they glue little strips of wood to the front of it.
              Yev
              Yev if you find a good source for t molding plz post it or let me know homedpot by me seems to only like metal i need plastic
              .______
              | '_ |__\___
              [(o)|___(o)] XB
              ._________
              | I__I I_I|_\__I
              [(o)______(o)]b VanPimpin'
              LostReceptions Apps D/L Here
              GPSGasoline- Rewriting
              CarPCNetwork
                http://www.t-molding.com
                  have you tried www.mcmaster.com they are awesome!
                  M10k
                  My Car Pc Install
                  My Boat Pc worklog
                    i will see what i can do, they also sell the shades stips for window shades, how of them have thick ridgid design, that you ccould easily cit with scissors, then glue to the cloth, and tack it into T- track, i am sure there is something made of ABS, that you can shape with heat gun, or a toaster
                    Yev
                    R. T. F. M
                      you could also use a router and some mdf to make a track
                      M10k
                      My Car Pc Install
                      My Boat Pc worklog
                        Then you could follow curves. I refinished an old cabinet for my grandma that had these type of doors. Looked pretty simple to build.
                        Failure is not an option....
                        It's installed by default on every version of Windows.
                          quick and easy solution, than just fabricate, and reinforce with some resin, and you are set
                          Yev
                          R. T. F. M
                            MDF is strong, why would you need to reinforce it?
                              Tambour (or rather finding them) sucks.
                              I started to make my own. I later abandoned it as I'd have to cut away too much of the dash inside.
                              I just used a sheet of 3/16 abs, cut it to size of the overall door, then cut it into slats, the tricky part was cutting out the tabs.
                              Then I glued it with spray adhesive to heavy canvas. It's quite strong, but doing the tabs by hand is a PITA.
                              I was going to have the slats made by a company that did CAD production. I believe it would have been under $40 USD to have them laser cut out of 1/4 abs.
                              Some pics of what I did, keep in mind, this was intended as a proof of concept.
                              GE Cache Builder | me@cardomain |Coolstuff :autospeed.com | bit-tech.net | Nitemax Ultra Pinouts
