Is wood ok?
  • Is wood ok?
    I've seen alot of people make their boxes out of wood... i assume the answer to this is... YES..
    My plan.. take my celeron/board outta my old gateway cut the computer case up, so that the board is stilll mounted to the sheetmetal and then attach this to my partical board...
    See any problems with this? The board will the be covered with carpet on opposite side...
    No problem with using wood. I used plywood to make my enclosre that holds the mobo, hd, ps. Wrapped it wiht carpet and it looks great.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
      ConvertedWS9,
      This person did pretty much what you are doing:
      http://www.mp3car.com/vbulletin/showthread.php?t=56599
      Carputer Project Status:
      0% - Mobo died on 2/17/08
      Check out the worklog for my '01 Pathfinder.
