Texture Paint Finishes - Picture Request
  • Texture Paint Finishes - Picture Request
    Hi guys, I know there are a number of types, and techniques to reproduce texture finishes. I have found a number of good threads with some examples, want to compile a technique listing including:
    1. type (brand) of paint (i.e. SEM, duplicolor, etc)
    2. distance paint was sprayed from
    3. number of coats
    4. clear coat - yes or no
    4. anything else relevant.
    Also, if you could provide CLOSE up pics of the final finish I would really REALLY appreciate it.
    Bueller...Bueller...Bueller. Come on guys...post them up. Having this all in one place would help everyone.
      Check out these two links:
      http://www.project33.com/Categoryart...egory=Interior
      I tried this method out on a bad cell phone battery I had not yet thrown out, just to see how it would turn out. It is super easy and turns out beautiful. If I can find that battery, I'll photograph it and post it, but the links above show exactly how to do the work and how it turns out.
        that looks cool
        Blaz3 [|||||||||-] 88%
          I found the battery. Keep in mind that this image is magnified, the actual texture is finer than it looks in this picture. I also subjected this piece to alot of abuse to check for durability. The bottom where you see the silver is an area where I did not sand the plastic first, and I was able to scratch off the finish. This didn't happen to the areas I sanded first. This piece has been banging around in my truck for over a year, and the finish has held up well. By the way I didn't use duplicolor. Apparently you can use any truck bed liner and vinyl color paint.
            I'm definitely using that method
            Car : 00' Chrysler 300M
            Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
            Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
            CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
              Great find man...looks good! Lets see others examples/techniques guys - keep them coming.
                heres some pics of my a pillars - a little dirty yet- i used sem texture with factory vinyl paint over it. drivers side has a temp gauge for the computer compartment and an a/f gauge under it. tweeters are mb quart q series. 5 1/4" woofers in kicks check out my sounddomain pages for pics. latest stuff is on page 11 as in sig
                99.9% complete.
                http://www.cardomain.com/ride/212327
                  that does look cool. i may have to try taht next time
                  here is mine. i sent mine off to www.leathermagic.com
                  New System in progress:
                  M10k
                  Phaze TD1500 ~> Seas g18rnx/p
                  Zapco Ref 500.1 ~ 12" tc-9
                  Transflective Xenarc
                  My Car Pc Install
                  My Boat Pc worklog
                    Freakin rich people.... geez
                      After reading this I was encouraged to try this. I had thought about it but had never seen any results. This is what I did this morning.
                      Here are some closse ups of how well the texture matches the original. It is awesome.
                      This is what I used for products. Wal-Mart for $11.00 total
                      The Car 2005 Scion xB
                      The Truck 2004 GMC Canyon
                        i used Vynl dye(same on as yours) and also SEM texture spray from goferauto.com
                        screen name here use to be MegaloRESE15"
