Attaching a head to a DC motor
  • Attaching a head to a DC motor
    I want to attach a servo head(one of those X shaped ones or a large circular one) to a dc motor with a high torque gearhead. I want to transfer the rotary motion of the motor to linear motion to drop a shelf about 2 inches. I didnt really want to use a serve because I just want to put it on a three way switch to lower and raise it when I want. Any ideas as to how I would securely attach one of these heads. Also do dc motors with gearheads have holding torque with no power going to them?
    http://www.servocity.com/html/3-12v_gear_motors.html
    Check that out, and the gearhead should hold just fine
    Tennessee Vols Fan
      Cool...thanks. I just want to make sure that it will hold, I'd rather not have to use any sort of latch or anything...it will be holding about 3 pounds.
        No, not on their own - they do not hold torque. Sometimes the friction in the gears, or the direction resists motion but they are not like a servo.
          hmmm...do i have a better option. Linear actuators are too much. I was thinking a power door lock actuator, but i think it would move too fast and it would not give me enough linear motion either. I don't think I can use a power antenna motor cause i dont have a ton of space. I wanted to stay away from a servo cause then i have to get a controller for it and everything. I was trying to stay simple.
            I guess it would depend on what gear ratio it is. Mine are 12vdc, 4 rpm's and hold just about anything I can attach. The bracket would break before the motor reverse
            Tennessee Vols Fan
              If you use a motor geared with a worm gear, then it should hold just fine.
              But don't take it from me! here's a quote from a real, live newbie:
              Originally posted by Viscouse
              I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
              eegeek.net
