Help - need ideas to cover console with carpet
  • Help - need ideas to cover console with carpet
    I want to put the monitor where the HU and EQ are now..
    So i made a console to move the radio and EQ into..
    From the beginning i decided i didn't want to spend the time sanding to get it good enough for paint, but now I'm having second thoughts.
    The carpet i had planed to cover it with is the same used to cover Sub boxes and i now came to realize it ain't very flexible.
    I'm at a lost how to do those rounded edges and if i have to use seams, what is the best technique.
    I wasn't able to find any how-to's other than to cover the (square/straight) speaker boxes.
    Thanks for any comments/suggestions
    M2-ATX Power Supply
    Windows XP SP3
    Have you tryed heating up the carpet to make it more flexable? When I am upolstering somthing that I can not figure out, I start with a big peice of paper and use that as a template. When I mess up with the paper, I just make a new peice and try again.
    120" Strech Limousine on 40's
    Cummins 5.9, tube chassis, 4-links, dana 60's, divored np205, 30 inch travel airbag suspension , POS hydrostatic steering, blah blah blah... I just need to finish it...
