EPIA "tv" out question
  • EPIA "tv" out question
    I just got my EPIA 800 mhz itx board. I have not been able to figure out how to enable the "tv" out feature to send the video signal to my LCD. I don't have a secondary monitor readily available at this time so if its in the BIOS I guess I have to wait to enable it. But if its a jumper I can't find the right jumper in the manual.
    Can anyone shed dome light on the subject?
    New site at
    http://customcarpc.dreamhost.com
    http://home.attbi.com/~rbarr110
    2002 Toyota Tacoma Doublecab
    You may have to change the jumper for the tv out..
    The rca for the tv out is also the pdif out there is a jumper on the board next to it.. consult your manual to figure out how to do that..
    If you boot up with the computer connected to a tvout and no vga it should automatically boot to the tvout
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
      I dont have VGA connected, just the rca out for the LCD, I have tried both settings for RCA/SPDIF with the jumper on the board. I still get no display on the LCD.
      I have tested the LCD on my home computer and it works, I guess I need to hook up VGA to see if ITX board is working.
      Any other suggestions?
      New site at
        Is your computer even showing post on the lcd??
        What OS are you using?
        aka Kumaneko
          Nothing shows up on the LCD, no post, nothing. I pulled the harddrive from my old setup and plugged directly into ITX to test it out. I can hear the HD clicking away but I get no display. I am using Win98 setup so that Winamp is the shell (i.e. boots directly to winamp)
          Thanks For the help
          New site at
            In my experience win98 will go to the lcd no matter what if there's no vga hooked up...
            I don't know what else to tell ya..
            Maybe your IDE cable is in backwards? you should still get post though...
            I'd call in an RMA If you can't get anything on the vga either
            aka Kumaneko
              Well I finally hooked up to VGA and the hard drive booted and everything was on screen....
              but to my surprise it was the wrong hard drive, it had WinXP on it. So I am starting the process of installing Win98 and trying it out the LCD.
              Thanks for the help, i'll let you know the results.
              New site at
                with xp you need to set the video card to the composite out then remove the vga and shutdown in order for it to stay on the composite.. once xp sees the vga again it will forget all about the composite
                aka Kumaneko
                  Everthing is working now, I switched over to the S-Video out and there are no more problems.
                  Thanks for the help.
                  New site at
                    The TV-output on the board is only 8bit color (256 colors). If you have it set higher than that (which I'm sure you do) that will be your problem (at least with the composite output).
                    [email protected] 1997 Blazer Dashpc Style!
                    VIA EPIA-M 9000 Hauppauge WinTv (FM tuner), 256 MB, 40 GB HD
                    Running Linux: Slackware 10.0, xmms, mplayer and Roadmap gps
