Epia CN10000 vs DirectX
  • Epia CN10000 vs DirectX
    Trying to run any 3D application on my CN10000 causes it to either freeze or reboot. Tried dxdiag and the DX7 test passes. For DX8 and DX9 it renders the first frame (cube) and then reboots.
    Any suggestions ? If it works on your system, what are your driver versions?
    The onboard video (S3 Unichrome) can't handle DX8, I'd guess.
    How about the Wiki?
      All VIA boards are Unichrome as far as I know. So does that mean graphic-wise all Epias are stuck in 2003 ?
        I have CN13000 running DX-9 without problems.
        I have VGA driver version 16.94.44.37 (the one on via.com.tw) and BIOS version 1.07.
        Hope this helps...
          Thank you very much kftqq !
          Can I have some more info on your system, please? WinXP SP2 ? What Hyperion driver did you install? Are you using BIOS default/optimized settings ? What are your AGP, aperture,etc. settings ?
            Glad to be of help...
            Standard XP Pro, SP2 using the optimised BIOS settings (I can't check the AGP settings right now, but I know for sure I haven't messed with them!)
            Sorry, I'm not sure what you mean by "Hyperion" driver...
              Hyperion is Via's 4-in-1 mainboard driver. Did you use the one on the install CD or something more recent from the website?
                Ah right.... I used the one on the website and it worked just fine. I'll run out the the car in a bit and double check all my driver versions for you, just to be sure
                  Thank you very much for checking all this !
                  I have installed WinXP 6 times now on this system and I want to make sure that it's definitely an isolated hardware issue before returning the board and trying to deal with warranty exclusions.
                    Cross,
                    I've checked all my driver versions for you...
                    VGA is 16-94-44-37
                    4in1 is 4.55v
                    BIOS is latest version (v1.07 off VIA site), on optimised defaults.
                    Have you tried not installing the VIA drivers and using the generic windows ones instead? If so will it run DX9? Casue if it doesn't then either, it's not a driver issue.
                      Well that wouldn't help since Microsoft's default VGA drivers don't do any DirectX anyway. MS abandoned software DX support back in the 90s.
                        Seems like I had invalid BIOS settings. Reflashing the BIOS and loading optimized settings fixed the problem. Driver versions do not seem to matter.
                          I stand corrected Glad you got sorted out anyway
                            I think this is what was happening to me. I didn't reflash it, but I loaded optimized settings. I'll reflash it if it keeps happening again.
                            The bios splash and the Windows boot screen gets offset to the side like a couple characters to the left (cutoff) and that's when you know the BIOS is messing up stuff. Try to clear it before you mess with too much with Windows software drivers, otherwise, you'll just end up rebuilding Windows over and over again and not make a difference.
                            Ken
                            IS300 IBP manual
                              The only time I have seen the screen cut off is when I enabled the TV out in addition to CRT. With CRT only it's centered.
