moving cards causes problems
  • moving cards causes problems
    I have my carputer set up in my room and when i have it running and bump one of my cards (pci or apg) the computer shuts down and says i had a hardware malfunction. I'm wondering if this a common and if it is will just gluing them in place help when i have the computer in the car?
    1998 Camaro Worklog Starting over, New setup for 2010
    This is exactly what I'd expect would happen... They're certainly not hot-swappable devices.
    But don't take it from me! here's a quote from a real, live newbie:
    Originally posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
      Hot glue will help them stay in place and is non-conductive.
      How about the Wiki?
        ok, i wasn't sure how the hot-glue would hold up to the heat in summer.
          you can use industrial hot glue which has higher melting point and should stand up fine to the summer heat.
            ok, thanks
