found a car adapter for mini itx case!
  • found a car adapter for mini itx case!
    http://shop.store.yahoo.com/priority...pomxexe2a.html
    made for the omnibook which uses 12v 5a output also!! im thinking this will work, how can it not? only prob would be maybe the plug doesnt fit but all you have to do is cut tip off the ac-dc one and change it on the car adapter.
    actually this is the correct one the other one has wrong output
    http://shop.store.yahoo.com/priority...hpom40061.html
      I have an application guide that came with my universal laptop supply that says omnibook takes 12v 3.65a, are you sure this one puts out 5a?
      aka Kumaneko
      "Don't make me moderate your ***!"
      Maxima of Doom - project thread - photo gallery
      mp3car system is currently FUBAR and finances do not allow for a correction of that situation
      Real computer hackers use a rotary cutting tool on their motherboard.
        yes the omnibook 800 takes 12v 5a, im positive, there are many diff omnibooks, each with different voltage. in fact my friend have the home ac-dc adapter and it says 12v 5a on the adapter.
          ShinkunoNamida, answer your PMs!
            I found an ac/dc on ebay, just to prove it does output 12v 5a.
            See attached photo.
              anyone find a cheaper car adapter yet? i would get it but for $60 i think i would rather just get a atx dc-dc one
                See attached photo.
                That doesn't really prove anything since the output can be higher than required. If the specs are for 3.65a then having the extra 1.35a is just a little extra.
                You can be a little above spec for this sorta thing.
                aka Kumaneko
