Harddrive problems (booting)
  • Harddrive problems (booting)
    Hi there, this is the first post i make but i'am reading this forum for quite a while now.
    I'm building my carputer now and i got it all in test phase.
    But now problems arrive; I got a brand new Maxtor 250GB on my Via-Epia V motherboard.
    When i got it running there are no problems, but when i reboot a couple of times my HD won't spin-up; i made a sound clip of what it sounds:
    when i let it 'cool off' and then boot, there are no problems and it spins right up.
    Is this a broken drive or do i need a better power supply?
    I'm asking this because when i was setting up windows i also got a old 12speed cd-rom hooked on. when the cd-drive was spinning my pc reseted itself so i discovered it was because the old drive; with a new 52X speed there where no problems...(old drives use more power)
    sorry for my bad English
    Will the power supply spin up a different drive? (yes may indicate the maxtor is bad)
    Will the Maxtor work on a different system with the same multi-reboot scenario? (yes indicates the drive is likely good)
    based on the results of the questions: Ask Maxtor for an RMA (Return Material Authorization), describe the issue to them.
    Read the FAQ!
