Directed Electronics HD Radio
  • Directed Electronics HD Radio
    Another HD Radio option, thanks to mitchjs
    solution cost will be around $220
    http://www.rush2112.net/
    http://www.directed.com/Products/Mob...o/HDRadio.aspx
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    See this thread for more info
    Hey,
    This topic has been posted already and it seems that there has been some progress in getting rudimentary software to work...
    DICE HD Radio Link
    Cheers
      uh, yeah.
      I was the one that found the DICE unit did the first post on using an i-bus adapter to control it.
      I was just pointing out another unit available, a bit cheaper, and actually probably closer to being able to have natively controlled by a front end
        I was wondering about that solution since it's a universal unit. Crutchfield has a rebate, so you can pick one up for $159 after $40 rebate.
        It'll be nice to add radio stations as entries to a playlist (like WMP and iTunes) instead of using separate software.
