Poll: Hard Drive mounted horizontally or vertically?
  • Poll: Hard Drive mounted horizontally or vertically?
    This topic is always a fun one to stir up some passionate debate. Answer the question, do you mount your hard drive vertically or horizontally? Also, if you desire, post how long you have had the drive in your setup and whether you use shock mounting or just bolt it to the car.
    25
    Horizontally
    52.00%
    13
    Vertically
    48.00%
    12
    Want to:
    Mac mini - horizontally, no shock mounting, 1-1/2 years. Previous PC used laptop drive, horizontally, no shock mounting, 1-1/2 years.
    Want to:
      When I first saw the thread title, I was all ready for some bashing and link to debates!
      Anyways,
      For 1 year 300Gb 3.5" drive horizontal mounting. Worked fine.
      Switched to a more power hungry mobo/cpu combo from a via, so I switched the power hungry drive to a 2.5" drive.
      For 3 months and still in there, 60Gb 2.5" drive horizontal.
      1.9in x 2.9in -- 47mm x 73mm
        how aout none of the above?
        i mounted mine on its side and attached to one side of the case.
        i dunno if this is "bad," but i havent had any problems in it for the year and a half its been like that
        2004 Impreza WRX CarPC Install
        I am willing to host any legal downloads that may benefit the CarPC community - PM for info
        "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
        DG4L
          My 200 GB 3.5" SATA is mounted horizontally on 1/4" stand offs for a year now with no problems, so far.
          <knocks on wood>
          Carputer Project Status:
          0% - Mobo died on 2/17/08
          Check out the worklog for my '01 Pathfinder.
            Old setup : 6GB Hitachi 2.5" laptop hard drive mounted horizontally on rubber grommits for shock absortion. 6 years service without failure. Retired due to dead mobo (bad bios flash).
            New setup : 8GB Seagate 1" compact flash hard drive mounted horizontally in mobo's CF socket, no shock absorbtion. 1 year service without failure.
              That sounds like vertically to me.
                I believe that yould be "vertically".
                The orientation has to do with the platters being horizontal or vertical.
                Mine's horizontal.
                How about the Wiki?
                  I'm vertical and after almost 1 year of Ireland's beautifully smooth (read crater filled) roads, not one problem. Disc is samsung 120gb 2.5"
                    Here we go
                    Horizontal, installed for more years than most (6+), in at least 4 vehicles one of which had a frame bending wreck.
                    No trouble with hardware at all.
                    TruckinMP3
                    Read the FAQ!
                      Two 3.5 drives (20gb WD and 80gb maxtor) grounded and sitting on firm foam for 1 year. I tried it horizontal, but my music skipped on the big bumps. No problems now.
