I have done something VERY stupid
  • I have done something VERY stupid
    Ok, so i got the dscustoms in dash 5.6" LCD for 225. Immediatly went to ratshack and got a power adapter so i could use it in my house (110v AC-12vdc adapter). I had been using it for about a week on vacation to play gran tourismo 3 (works awesome). THen I went to lincolnl to show my friend the screen and not thinking clearly, wired it up backwards. (I know I know, I am a f*****g retard). Andway after some intresting smells and a bit of smoke, the screen dosent work. My first thought was...theres 225 down the damn tube. I began to check out the baord and noticed that a diode poped (prolly what smoked). So i took it to ratshackand found a suitable replacement (the IN4004 i think). I replaced the diode on the board and it still didnt work. it looks as though the trace leading to the diode may have burned up so I cant get a good connection. Anyone else here been stupid enough to do the same thing? Any ideas on what do do to fix it, or try to fixit? Anyone know who makes the screen? Where to get a replacement baord?? Hopefully I wont be completely out of luck. ****!!!!!
    90% Done
    60W DC-DC & shutdown controller
    Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
    Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
    All in a shiny White 2000 V6 Mustang
    Click here to visit my NEW PhotoAlbum
    If its just a burnt track why not solder a thin piece of wire from the diode to the other end of the track? I have had to do this with other things I have fried in the past.
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
      That was my second idea. I tried using a piece of wire to connect the good side of the track to the diode ubt no luck, I was also having problems with my powersupply at that time to, so that may be the issue. I just bought a new powersupply and will test it out.
      90% Done
        good luck! hope you fix it
        My cars
