Can I add another fan to a VOOMPC version 1 case?
  • Can I add another fan to a VOOMPC version 1 case?
    I have a fan on the CPU and one on the case.
    The case has space for 3 but it looks like my Motherboard only has two fan connectors.
    Any ideas or suggestions on add 1 or 2 more fans if at all possible?
    VoomPC, VIA C7 1.5 Ghz, 7" Newision LCD, 80 Gig WD 5400 RPM Laptop Drive, M2-ATX, RoadRunner, iGuidance, Freedom 2.0, AT&T Natural Voice Hot Babe Audrey. All wrapped up in a piece of crap Suzuki Grand Vitara.
    if it has a spot for the fan, get one that is the right size and uses a 4 pin molex (standard power) connector.
    TruckinMP3
    Read the FAQ!
      the motherboard only has two fan connectors (currently for the one case fan and the cpu fan)
      Are there adapters or do you mean connect elsewhere (ie, the power supply or something)
