Opinions of the Asus M2N-MX?
  • Opinions of the Asus M2N-MX?
    How does this board go as a carpc?
    Specs
    CPU
    Support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron
    AMD Cool 'n' Quiet™ Technology
    AMD64 architecture enables simultaneous 32-bit and 64-bit computing
    AMD Live!™ Ready
    Chipset
    NVIDIA GeForce6100 / nForce430
    Front Side Bus
    2000 / 1600 MT/s
    Memory
    Dual channel memory architecture
    2 x 240-pin DIMM, support max. 4GB DDR2 800/667/533 ECC and non-ECC,un-buffered memory
    VGA
    Integrated GeForce 6100 GPU
    High Definition Video Processing with max. resolutions to 1920 x 1440
    Expansion Slots
    1 x PCI Express x16
    2 x PCI
    Storage/RAID
    NVIDIA MCP61P
    1 x UltraDMA 133/100/66/33
    2 x Serial ATA 3Gb/s with RAID 0, RAID 1
    NVIDIA MediaShield™ RAID 0 and 1span cross Serial ATA drives
    LAN
    PHY 10/100 LAN
    Audio
    ALC662 High Definition Audio 6-channel CODEC
    Support Jack-Sensing and S/PDIF out interface
    USB
    8 USB2.0/1.1 ports
    Manageability
    WfM 2.0, DMI 2.0, WOL by PME, WOR, PXE
    BIOS
    4Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0
    ASUS Features
    ASUS Q-Fan
    ASUS My Logo
    ASUS CrashFreeBIOS2
    ASUS EZ Flash
    Back Panel I/O Ports
    4 x USB 2.0 ports
    1 x COM1
    1x Parallel
    1 x 5.1 channel Audio I/O
    1 x RJ45
    1 x PS/2 Mouse
    1 x PS/2 Keyboard
    1 x VGA/RGB
    Internal I/O Connectors
    2 x USB 2.0 connector supports additional 4 USB 2.0 ports
    1 x S/PDIF output connector
    High Definition Front panel audio connector
    4-pin CPU Fan / 1*Chassis Fan connectors
    20-pin System Panel connector
    CD audio-in connector
    24-pin ATX power connector
    4-pin ATX 12V Power connector
    Accessories
    1 x Serial ATA cables
    1 x SATA power cable
    1 x UltraDMA 133/100/66 cable
    1 x FDD cable
    1 x I/O Shield
    User's manual
    Form Factor
    uATX Form Factor, 9.6" x 7.6" (24.5cm x 19.4cm)
    Running an AMD Sempron 3200, 512mb ddr2 ram, 3.5" W.D. 80gb Sata hdd, and some random usb junk (gps, bluetooth).... how power hungry would it be? Would an M2-atx 160w psu handle it or would i be better off with an opus?
