Cutting off PCI slots - anyone tried it?
  • Cutting off PCI slots - anyone tried it?
    Hi, I need to wedge a new thicker VGA card in My custom PC case but in order to get it to fit I will need to cut off or desolder the PCI slots. has anyone tried this? any tips / pitfalls I should be aware of? I was planning on filling the dead slot with Hot Glue in order to insulate it.
    Comments please!
    well I have never removed a pci slot but i would think that a good desoldering turn would be your friend as to the pitfalls i have no idea what to tell you.
      lol, that would be the neatest but theres an awful lot of desoldering to do. I may be able to find an old board at work to play with first. as the pitfalls I was wondering how Windows may react, I'm guessing that it won't as the circuitery would still be present just the actual slot would be missing. If I do it I will post the results here!
        as long as you do a good job and dont overheat the traces and blow the multi-layer PCB or heat up a nearby component it should have no adverse effects.
        Just get a desoldering braid, lay it over the bottom pinsand run your iron over it.Then it should be mostly free and do it by feel then.
        1.9in x 2.9in -- 47mm x 73mm
        Buy now in the Store
