Via NX15000EG Nano Audio headaches... Help...
  • Via NX15000EG Nano Audio headaches... Help...
    The via manual lists the following connectors. (they make you make your own cables with this board).
    1 SPDIF_OUT
    2 +5V
    3 GND
    5 LINEOUT_R
    6 LINEOUT_L
    7 LINEIN_R
    8 LINEIN_L
    9 MICIN1_R
    10 MICIN1_L
    12 NC
    13 AGND
    14 AGND
    It seems that no matter which grounds I connect my cables to, I can either get Linein to work, or lineout. Not both at the same time, it's a ground issue, the problem is that the manal is all the information via provides anywhere I've seen. are you supposed to tie all grounds together???
    Anyhelp would be greatly appreciated.
    Well that is for front panel audio.
    Why dont you just use the audio out on the back ports? You can only use 1 at a time.
    1.9in x 2.9in -- 47mm x 73mm
      not that easy.... nx15000eg and nx12000eg boards have no rear connections... everything is board headers... vga, audio, usb.... VIA kindly decided to not provide anything but usb and vid cables.
