Cannot change Radio station
  • Cannot change Radio station
    I have G4 running Infill station (No, Iím not from US and my G4 not from MP3CAR store).
    Iím really like to have my G4 running SD over the Infill Station.
    I installed the SD trail version and I running it for testing .
    For clarification, I have installed on my system:
    a. Windows XP SP2.
    b. Full OS updates (including WMP 11)
    c. The whole drivers.
    d. Infill Station.
    Up to here Ė the system full functional and I can use Infill station with no problems.
    e. Over this installation - SD
    I got some problems and I need some help in order to run SD properly.
    When switching to radio (AM/FM), I can hear the last station that tuned using Infill Station but I cannot change it.
    Itís look that my installation of SD cannot control the internal radio tuner.
    Read this thread.
      Thanks, its works.
      Do you know how I can change the scan steps?
      The scan running on the Odd frequency and I like it to scan also the Even frequency.
        What version of SD are you running? I know the latest update tweaked the stereo settings to add even stations (or at least a command swicth that allows you to add or drop the even stations)
        _______________________________________________
        All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
          which infill station Software you use? 1.6.4?
            No, the infill station software version that I run is 1.6.6
            In infill station software the scan running without skipping the Even frequency.
              hmm.. crazy..
              i will try it the next time, when I behind my G4. Do you try, uninstall all Infill Station and SD Software, restart your G4, then delete all directorys that left in c:\program files
              like maxan, infill and streetdesk, than go to registry (regedit) and search with F4 key for this 3 keys "infill, streetdesk maybe maxan, and delete the tree with this items.
              After them, install the newest SD or Infill again.. (or perhaps, only one first and then try again..)
              I hope you understand that a little bit, i do things like this all day in my job, i evaluate every Day things that are "nice to have" ;-) but i cannot speak really good english :-(
                Yes, I do. I even tried reinstalling the whole widows again.
