BMW iBUS integration issues
  • BMW iBUS integration issues
    so i've tried setting this up from researching endlessly here and hacktheibus but i still cant get my steering wheel controls working. i'm using reslers usb ibus interface, i've installed it correctly, but i can't cant any signals working, either by the button or by emulation.
    has anyone else had such issues, and/or have possible suggestions for what i could be doing wrong?
    your feedback is appreciated....thanks.
    2000 Acura 1.6 EL (showcar) :: retired
    2003.5 BMW M3 :: new project
    ClubEL.ca | ClubCSX.ca | BlackBoxHQ.ca | DCSonline.ca
    i've had this happened to me before.
    #1. did you install a new steering wheel with buttons?
    (if so, you probably didnt have buttons on your old steering wheel correct)
    if this is the case, you will need to make a harness connecting the wires coming from your new steering wheel to the LKM/LCM. There's a DIY somewhere on the internet. This happened to me about 2-3 years ago when i attempted to retrofit a steering wheel with buttons onto my E46. I was having trouble just like you until i found out myself that a wire harness must be created.
      no..my car is an 03.5 ..so it came with the steering wheel controls.
      i haven't revisited this issue since my mobo is off for rma, but thanks for the input.
