custom switch panel
  • custom switch panel
    i am trying to make a panel in the dash to have 4 or 5 switchs, 1 to reset the mobo, 1 to turn on/off the sub amp. what kind of switch would i need and do i just place the switch between the remote on wire and amp thanks
    You should wire one for spell check.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
      You should get a switch to not be a jerk.
      Anyway, for the OP, a mobo switch doesn't need to be anything more than a push button switch, normally open. Just attach it to your mobo.
      For an amp just putting a switch between the remote line should work.
        fc3s is correct, but maheriano was pretty funny. what kind of switches were you thinking of? adding switches; imho, detracts from a seamless installation. If i were you i'd hide them if you really needed to have the switches. another alternative to switches is fusionbrain, it would be a great gadget to incorperate to control everything you needed/wanted to have a switch besides the mobo reset switch. That would leave you with only one physical switch that you could easily hide.
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
          fusion brain looks awesome i'll look in to it thanks wow this is really good? but i am a bit confused how would i set up fusion brain with the amp or with the car to control each function
            you would connect the amp or whatever you want to use to the fusion brain (not sure if it could control them directly, you may need relays), basically the brain will turn on a relay, which allows power to go to whatever unit
            its a good idea, more than good enough for the sounds of what you want to do, and i've never seen anything in the same price range that can do anynthing close to what the brain can
              the FB can be used as a remote directly. It can provide up to 500mA of current at the input voltage (probably 13.8v with the car on). That is more than enough for most amps. And that is 500mA per output.
              And as a plus, it will give you 100% no thump.
              1.9in x 2.9in -- 47mm x 73mm
                well here is what i basically need i have 3 amps, i just want to control the remote turn on so i can turn on/off the amp anytime. and then also control the interior neons, my question is how would i use the fusion brain to connect them and also to control other function as describes in the thread
                http://www.mp3car.com/vbulletin/fusi...ion-brain.html
                thanks
                  thanks
                  It is really simple. Just attach a relay to the output pins, and voila a software controlled switched.
                    so you mean the relay from the site which is 25A
                      yes
                        how would i wire this to the amps, and is this the same relay i use to connect to door locks, window control,neon etc and is there a general wiring for this relay or does it depend on what function you are wiring thanks
                          Yes it is "one relay to rule them all" sort of deal.
