5v - 12v
  • 5v - 12v
    I have a TRUST 4port 2.0 USB hub, which has a green light on
    i need to give it some power, but whats the best way to get a 12v - 5v power thingy, to come on only at time the computer is on
    im using a laptop in a car.
    i just dont want to hook up 5v all the time (even when the cars off)
    Something like this: http://store.mp3car.com/Carnetix_CNX..._p/pwr-016.htm
    How about the Wiki?
      Are you sure you need a powered hub? If not, some computers don't power the USB line when turned off. You may not need a power supply for your hub. Some computers, though, do power the USB hub even when off or in standby. Depends on your model.
      Want to:
        its a nx9010 laptop base
        i had a flash drive in earlier, laptop off but the light cum on the pen drive once plugged in to the usb socket
          No, what you need is a 2A POSITIVE VOLTAGE REGULATOR, L78s05cv.
          http://www.datasheetcatalog.com/data...L78S05CV.shtml
          They keep 4.95V even if voltage in is fluctuating. I am using them myself to power my USB hubs in the car.
          An advise, use some simple heat sink to cool then, for example a chipset cooler from an old motherboard.
          Good luck!
            Good luck!
            im interested in this as well. Might you have any pics of how these are setup with your system?
