VERY cheap car PC possibilities
  • VERY cheap car PC possibilities
    http://www.fit-pc.com/index.htm
    Check it out, its on the cheap, and could handle basic carPC needs. I think its...$280?
    500 mhz processor with 256 MBs of ram. Not bad
    CarPC status:
    [XXXXXXXXXX] 100% Complete
    [XXXXXXXXXX] 100% Installed
    [XXXXXXXXXX] 100% Software
    CarPC v1.2 is now in effect. Software updates and hardware additions to come.
    Looks awesome with great potential (especially the low power draw), but, 500 mhz would hurt for a lot of people as far as being underpowered goes.
    My Grandma & Her Friends on Their Spring Vacation
      Wow...its hard to believe that it only draws 5 watts. I am running a carpc with xp and centrafuse on a 550mhz p3 machine and it runs just fine with no lag. I am not sure how that 50 mhz will affect performance though.
        fit-PC Specifications
        w AMD Geode LX800 CPU @ 500 MHz
        w 256 MB DDR (non expandable)
        w 40 GB Hard disk, 2.5" 44-pin IDE interface
        w Dual 100 Mbps Ethernet
        w SXGA graphics controller, from 640x480 up to 1920x1440
        w Two USB 2.0 high speed ports
        w Speaker and microphone interface
        w RS-232 serial port via RJ11 connector
        w Single 5V supply, 3-5 watt, fanless operation
        w Size: 120 x 116 x 40 mm, 450 gram
        w All aluminum case, black anodized finish. Splash and dust resistant
        w Operating temperature - 0-70oC
        w Gentoo Linux preloaded, kernel 2.6.20.
        Windows XP easily installable using USB CD-ROM drive
        Seach for GEODE on these forums. People have used Geode-based systems in builds before.
        It's low power-draw, but also low-powered. You're not going to be rocking 3D visualizations or ripping DVDs on something like this.
        How about the Wiki?
          Geode NX != Geode LX
          Now Galileo is real. Muhahahahaha :p
            Is the CPU upgradable? If I had a spare AMD would I be able to toss it in? Kinda get rid of the OVERLY low CPU size...granted, it would pick up the draw but not by much if I did a small upgrade...
            ~Fin~
            My First Install. Be gentle with my 03 Vibe GT
              thats neat, i had an 800mhz amd, with 512ram and to be honest that just about coped running PC navigator, Road Runner & Phone control.net (Using decent skins ).
              You would have to really tweak windows to get the best out of that, but still its a great idea and size!
              CarPuter Progress:
              Planning:-----> [||||||||||] 100%
              Hardware Buying:-> [||||||||||] 100%
              Software:-----> [||||||||||] 100%
              Installing:-----> [||||||||||] 100%
              Current Project= Making skins in photoshop...
                sorry, I'm pretty sure it wont be upgradable. Its not an intel/amd cpu so it will have a weird socket, and unfortunately, its RAM isn't upgradable.
                Install Xp Lite, that works on the barest of systems just fine. (AKA XP without the CRAP)
                I see no prob running the music, frontend, and navi all at the same time. (I'm a legacy hardware buff, i can't throw an old PC out)
                CarPC status:
                  http://gizmodo.com/gadgets/small-lov...iny-310537.php
                  http://www.extremetech.com/article2/...2194852,00.asp
                  I know that Roadrunner needs a bit of a system to run on...I don't know how well a Geode at 500Mhz does...but a Mini-itx 10000 (1Ghz) system is the equivalent of an 800Mhz cpu...and that is about as slow as you can go for RR.
                  But it is tempting.
                  current projects
                    Runs from 5 Volts. That would be temping to buy. Easy to get a steady 5 Volts from a car.
                    Um, I guess this is where you put something witty.WITTY
                    My Web site, in the design stage. http://home.comcast.net/~cstrachn
                    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
                      Processor is a little tooo slow for me...
                        Now...
                        Something like this to control devices or something...
                        As a music player it would be OK.
                        How about the Wiki?
                          lol i considerd making a car pc outta an old one i had laying around. it turned out to be like 500 mhz nd the thing lagged even playing a screen saver. ive been trying to strip it down as much as possible but it still laggs pretty bad.
                            You try XPLite or something like that? Maybe even Win 2000 (its XP without the crap, it runs great tell you the truth) Usually a RAM upgrade is all you need to boost a slow system.
                            CarPC status:
                              Comp USA recently had a two day sale on an Acer laptop for $299. For that you get a big screen (15.4")and a 1.6 GHz processor. The sale is over, but someone showed me a $399 lap top that they sell at that price all of the time. I think they are a bit harder to integrate, but that's a lot of bang for the buck.
